Where do i check the code?!??
Old May 31, 2003 | 09:03 AM
Yogster's Avatar
From: George Town, Grand Cayman, Cayman Islands B.W.I
Default Where do i check the code?!??
I no its a dumb question. I am kinda new to this thing, but........................
I have no idea where or how to test the ecu (the engine code) I have a 1994 Honda integra SI (same as the Acura gsr) Please help Also I have a problem sometime my car shuts off after being on for like a second. I also have a sensor prob (I THINK). My car starts up @ 3-4k rpm, then jumps up and down between 1-3k and suggestions???
Old May 31, 2003 | 09:43 AM
neo1z's Avatar
Default Re: Where do i check the code?!?? (Yogster)
Look under the passenger side kick panel, there is a little blue guy you need to jump. When you jump it (with a paper clip), turn the ignition on (not the car), and watch the CEL blink. Long blast means ten. Short is one.
Long long short short = 22 for example. I have a history with that one.
Can someone post a pic?
Old May 31, 2003 | 10:27 AM
IN VTEC's Avatar
Default Re: Where do i check the code?!?? (neo1z)
It's above the passenger-side kick panel, right next to the glove box.
It's a 2-pin connector with a brn/wht wire and blk wire. The connector is stuffed in a blue boot along with another connector (probably 3-pin). The boot is taped to one of the two wire harnesses if it's never been used before.
Old May 31, 2003 | 11:30 AM
theman-dlh's Avatar
http://www.c-speedracing.com/faq/06.php
prelude_93vtec
Jun 17, 2019 09:31 PM
claysold
Sep 12, 2005 07:57 PM
redintheface
May 14, 2003 02:21 PM
Ek00fbp
May 4, 2003 11:13 AM
SlowB16
Mar 4, 2002 05:20 PM
