No turn signals?
No turn signals?
Turn signals not working on a buddy's DC. Fuse is fine. Relay is fine, works in another car. Signal/combination switch is fine, also works in another car. Any ideas? TIA.
ⒽⓉ ④ ⓁⒾⒻⒺ
Re: No turn signals? (Eggman)
Try and see if you're getting a voltage at the connector. Just turn on the hazards & test the DC output. If you're not getting any juice there might be an electrical short or a problem.
where is that located? that guy said he checked his relay and it's fine. mines is fine too. i'm talking about the one right by the fuses under the dash. is there another one?
well, for me, when i turn my signals on, the blinker lights on the cluster don't even blink. and it doesn't make that clicking noise either...but it does all that when the hazards are on. and i got dual filament bulbs.
Re: No turn signals? (mister 5)
Did either of you ever figure this out? I've got the same problem on my Prelude. Hazards work, relay is good, combo switch is good, wiring harness is good . . . .
Someone else suggested it was probably the "flashers", but I can find absolutely no mention of such an item in the helms. They're not on the wiring diagram, either . . .
Re: No turn signals? (Daemione)
Do you guys have aftermarket radios? maybe they are connected wrong I had a radio connected wrong and it shorted out all my lights. Even if a proffesional instaler installed it most of those guys are idiots no offence H-T board. check the dash board fuse box for shot fuses replace them and see if they blow again if so take a small peace of thick round wire like coat hanger make a u shape and plug it in fuse box for like a minute while its in there look and smell for smoke whatever smokes is your problem could be lights, radio, etc. if not id have my computer looked at.
