Pulling?
Heres my problem, I have a 95 LS with stock suspension, Rota circuit 8 wheels with Kumho 712 tires. So my problem is on roads where the is ruts from wear or groooves from patching my car wants to follow them alot. It's like it has a mind of its own. On roads where they use cement or it flat it tracks perfectly stright. My alignment is perfect I have checked it several times. (I used to work for scottsdale acura) I have put my stock rims and tires on and it dose the same this but not nearly as bad. Strange, It may not be the tires if it is still doing it with different tires. What about suspension bushings being worn? It looks like my car has been hit in the rear before but not to bad I think. I don't think the body is tweaked but could this be my problem? Anyway I have asked everyone I know and have been told many tires its the tires? I am not sure, So I thought I'd ask you all. Any positive advice would be great thanks.
i think thats just a normal FF problem dude. . actually, even my FR cars used to do that. . . FF cars i think get it worse thoguh because of the power goign to the front. I'm sure the tires and wheels are some of the reason it happens, but as far as i know. .its pretty normal. . (either that, or everycar i've ever owned is messed up :cP ) hope its the latter
wtsapexipowerfc
Apr 27, 2011 07:26 AM
User 5426
Suspension & Brakes
Jan 30, 2006 10:07 AM
