Need Help!!!!
Old Jun 19, 2003 | 09:29 PM
Brian-Brian
Guest
Posts: n/a
Default Need Help!!!!
Radiator leaking coolant but it';s not from the radiator it's looks like it near the oil pan wah can this be please help out
Old Jun 19, 2003 | 09:33 PM
SMZ GSR's Avatar
Default Re: Need Help!!!! (Spoon_b18)
hmm, sounds like it could be the water pump...i had the same problem. how many miles on the car? have you had the timing belt changed?
Old Jun 19, 2003 | 09:34 PM
mr.beeks's Avatar
if its on the timming belt side
its your water pump.
change it as soon as possible..
Old Jun 19, 2003 | 09:39 PM
Brian-Brian
Guest
Posts: n/a
Default Re: Need Help!!!! (SMZ GSR)
i have 115k timing belt and water pump changed at 90k
is it time again?
Old Jun 19, 2003 | 09:48 PM
mr.beeks's Avatar
if it was an aftermarket pump yes
you should buy
OEM this time so you dont run into the same thing again..
Old Jun 20, 2003 | 01:24 PM
SMZ GSR's Avatar
if it was OEM then it shoudn't have gone out again yet. If it's OEM take it to the dealer (i know it's past 12k miles but sometimes they'll still help out)
Old Jun 20, 2003 | 01:33 PM
jacobyb's Avatar
It's your pump. I am replacing mine right now. Good luck with the crank pulley removal. It's a bitch. You are going to need the special tool if you are going to do this yourself.
Old Jun 20, 2003 | 08:23 PM
GirlyGS-R's Avatar
it could also be your hoses too...
barrera
Jan 2, 2010 03:09 PM
Capsule Kid
Aug 9, 2005 01:20 PM
rolla01
Jun 25, 2004 07:46 PM
DRKSol
Jul 6, 2003 10:52 PM
parasonic
Jun 16, 2003 06:26 PM
