Hidden Leak....
Old Jun 22, 2003 | 10:36 PM
DC2LsVtec's Avatar
Default Hidden Leak....
I keep loosing fluids from my overflow in basically a day after i fill it up and my car stays hotter then it usually is. I see liquid on the ground after I turn off the car. Does n/e body know what is wrong? the leak is coming from underneath the intake manifold and I don't know where I should start checking......
Old Jun 22, 2003 | 11:55 PM
Loveless's Avatar
Default Re: Hidden Leak.... (DC2LsVtec)
crawl underneath the car and look, some hose is probably broken
Old Jun 23, 2003 | 06:25 AM
Teggy94's Avatar
i just did a engine swap, and my car is doing the same thing.. crawl under and try to figure out what the liquid is... in my case its water, you may need to replace your water pump!
Old Jun 23, 2003 | 10:32 AM
Loveless's Avatar
Default Re: Hidden Leak.... (Teggy94)
i am leaning toward coolant hose somewhere
Old Jun 23, 2003 | 11:52 AM
JimBlake's Avatar
Default Re: Hidden Leak.... (Loveless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">i am leaning toward coolant hose somewhere</TD></TR></TABLE>
Or maybe that long tube running from the waterpump over to the thermostat. There's O-ring seals or something like that in both ends.
Get under there & take a look. Usually there's some crusty deposits around the leak.
dwuknoit
Jul 5, 2008 09:19 PM
syler
Apr 23, 2007 04:42 PM
lax1089
Mar 30, 2007 04:11 PM
vietkangta
May 17, 2006 08:28 PM
Understeer
Jul 23, 2003 02:53 PM
