Help with header gasket
Old Jun 19, 2003 | 09:56 PM
cccccccc's Avatar
Default Help with header gasket
i just installed a 4-1 header and it sounds like its leaking at high rpm.
is this becuase i took the old gasket out and cleaned it, is there i certain way it is supposed to go?
or shoudl i just buy a new one ?
thanks
Old Jun 19, 2003 | 10:06 PM
frogsr's Avatar
Default Re: Help with header gasket (c13r)
installing a header will give you that hissing/leaking sort of sound afterwards. if you torqued down your bolts correctly and your header gasket was in good condition then maybe it's just the new sound of the header that's causing you to think there's a leak?
Old Jun 19, 2003 | 10:53 PM
cccccccc's Avatar
ya the gasket was in good shape and i torqued them down good, thanks man
Old Jun 19, 2003 | 11:03 PM
mickey513's Avatar
replace the gasket, it's like $15.
jay di em02
Jan 28, 2007 11:00 AM
gtowni3
29
May 12, 2005 03:14 PM
Broken Gearbox
Oct 24, 2003 10:49 PM
Loveless
Jul 29, 2003 08:41 PM
92TEGsrSC
Jul 29, 2003 05:57 PM
