How do I remove speedo needle..or reset mileage, or both!
I am selling my cluster to a buddy, and I want to change mileage to reflect his miles. As far as I can tell, I can't spin the wheels without taking off the needle, to remove the front face. Anyone know how to safely remove needle, or even better would be to change mileage, and not have to remove needle!! I need help now!
~james
~james
Re: How do I remove speedo needle..or reset mileage, or both! (SleepyEG)
bump! please help! I have my cluster apart, ready to install, need to change mileage first!
~james
~james
as far as i know you cant roll back the OD.. Its that way on purpose so people dont roll back their cars.
Re: How do I remove speedo needle..or reset mileage, or both! (cjohnson_2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjohnson_2 »</TD></TR><TR><TD CLASS="quote">as far as i know you cant roll back the OD.. Its that way on purpose so people dont roll back their cars. </TD></TR></TABLE>
Yeah, it would be stupid if it weren't designed that way
Re: How do I remove speedo needle..or reset mileage, or both! (mskibbz-T)
Let me add a bit on how I used to do it on clusters I sold. Keep in mind this is very time consuming.
take the speedo out of the plastic case so that you have only the speedo in your hand.
I attached a pencil with eraser side out in a drill.
There is a pin that sticks out of the number rollers on the back of the speedo.
I used the soft eraser to grip onto the pin and roll the numbers forward until the proper number is reached.
Re: How do I remove speedo needle..or reset mileage, or both! (HondaIntegraLS)
well, I'm glad I have lots of sweet intuition. I took off the needle, and you can easily remove the bar that interlocks the gears together...only hard part is getting the needle back on in the correct position. So I got my mileage right, but I can't get the needle on in the right place...any comments on that?
~james
~james
i think you have to give it power, like putting it in the car, then when it gets power, the needle will want to be at zero, so you push it back on so that its at zero.
Re: How do I remove speedo needle..or reset mileage, or both! (Sukebei Oni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sukebei Oni »</TD></TR><TR><TD CLASS="quote">i think you have to give it power, like putting it in the car, then when it gets power, the needle will want to be at zero, so you push it back on so that its at zero.</TD></TR></TABLE>
yeah, i had a tach that did that.....
jdmpower363
02-24-2009 09:01 PM
JunkyardAccord
16
03-07-2008 02:18 PM
