how fast with this setup?
Old Sep 10, 2003 | 07:07 AM
LiveWire401's Avatar
Default how fast with this setup?
Starting stock
DC Sports 4-2-1 Ceramic Coated Header
AEM Cold Air Induction
Apexi N1 Exhaust
Skunk2 Intake Manifold
JE Pistons
Crower camshafts
Anything I shouldn't get or what else do I need?
Old Sep 10, 2003 | 07:10 AM
Default Re: how fast with this setup? (LiveWire401)
Forgot to say what car... 98 2dr LS
Old Sep 10, 2003 | 07:13 AM
fivespeedintegra's Avatar
take it to the track....it's the only way to find out. too many factors figure into a 1/4 time (driver skill, temp, track condition, tires etc etc...)
Old Sep 10, 2003 | 08:11 AM
jimc93si's Avatar
Get some cam gears and have it dyno-tuned, then take it to the track.
'Afore ya go, how many miles on your timing belt?
Old Sep 10, 2003 | 08:15 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiveWire401 &raquo;</TD></TR><TR><TD CLASS="quote">Starting stock
Apexi N1 Exhaust
JE Pistons
Crower camshafts
Anything I shouldn't get or what else do I need?</TD></TR></TABLE>
Uh, your description sucks. If you were a little LESS VAGUE, someone maybe able to give you a ballpark time. What Crower cams are you running? What pistons? What compression? Any fuel management, chipped ecu, afc, etc?
Seriously, you want an answer to a question that's impossible to answer. You could at least get a general idea if you provided the relevant information.
Adam
Old Sep 10, 2003 | 08:27 AM
VintegraGSR96
Guest
Posts: n/a
Default Re: how fast with this setup? (arw321)
not lower than 14.8
Old Sep 10, 2003 | 08:40 AM
JDM_Risa's Avatar
Default Re: how fast with this setup? (VintegraGSR96)
you gotta be more detail for real..........what kind of rods don't tell me your running stock rods with JE piston,..........what crower stage and compression like stated before........dyno tune is the key
you should get valvetain if your running some higher lift cams with more compression that should make some nice power in the upper powerband.
Old Sep 10, 2003 | 10:44 AM
Audi A4's Avatar
Default Re: how fast with this setup? (fivespeedintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fivespeedintegra &raquo;</TD></TR><TR><TD CLASS="quote">take it to the track....it's the only way to find out. too many factors figure into a 1/4 time (driver skill, temp, track condition, tires etc etc...)</TD></TR></TABLE>
geezz wont they ever learn that its not gonna do waht we say, that you gotta take it to the track to really know
Old Sep 10, 2003 | 12:15 PM
blakacintegera's Avatar
you might as well save your money up and do a motor swap or do a nasty turbo setup. i've seen alot of people blow money on ls motors just a be a little bit faster than a stock gsr.
Old Sep 10, 2003 | 12:24 PM
B16OnTop's Avatar
Default Re: how fast with this setup? (blakacintegera)
15.5
Old Sep 10, 2003 | 12:35 PM
quikB18B's Avatar
Default Re: how fast with this setup? (B16OnTop)
Not to be harsh or discouraging, but damn dude that seems like a waste of $ imo. Thats atleast 2k in parts, + labor all toward an Ls, 1.8 motor, non vtec, long geared tranny. Even if you were to make descent power, you tranny is not suited for all motor. Theres another $750 for a gsr tranny. If you have that much $ just go turbo, you will be faster for the same price. With those mods you will still be racing na gsr's with bolt ons
If you are convinced of the myths that turbo is unreliable than i would do an ls vtec swap, before going all motor ls.
Go Turbo!!!!!!!!!!!!!!!!!!
maal15
Jul 24, 2008 07:12 PM
dhakis
Honda Civic (2006 - 2015)
Sep 21, 2007 11:54 AM
groundedcivic91
15
Aug 13, 2004 07:58 PM
Smoking LS
Nov 11, 2003 05:28 PM
