is it easy to adjust clutch?
Re: is it easy to adjust clutch? (tegrunner)
Umm, what generation of Integra? If it is a first or second gen, then yes it is easy. If it is a third gen, well, it ain't that easy because you can't.
i need to revive this thread.
i have a cable tranny and need to know how to adjust it. the clutch engages about two inches from the floor and when i let the pedal out, there's a good inch or two of slop at the top.
Re: is it easy to adjust clutch? (seanb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seanb18c1 »</TD></TR><TR><TD CLASS="quote">here ya go.
http://www.advancedclutch.com/v3/tech.html </TD></TR></TABLE>
sweet... but i have a cable tranny. i'm assuming it should be adjustable kinda like the throttle cable?
scratch that. i just checked. this car has a cable to hydro conversion. no way to adjust hydro trannies, right?
Modified by kaj at 3:21 PM 9/23/2003
Re: is it easy to adjust clutch? (kaj)
You should be able to adjust the pedal height with the pushrod behind the pedal. There's something in the Helm manual about it but I haven't had to do mine yet.
Re: is it easy to adjust clutch? (JimBlake)
Yes, you can adjust the pedal height and engagement point with the hydro tranny. I just replaced my master and slave cylinder and had to do this. There is a detailed description of what to do in the helms manual, but I don't have it here at work with me and I'm not sure I could explain it without the picture for reference. Maybe someone is at home and could scan that page for you. If not, I'll do it when I get home.
Re: is it easy to adjust clutch? (C_tech97GSR)
for the hydro clutch, there are two 12 or 14mm nuts(i forgot which) on the master cylinder. one is a lock nut, the other you turn to adjust the pushrod length. there you have it.
Re: is it easy to adjust clutch? (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt »</TD></TR><TR><TD CLASS="quote">for the hydro clutch, there are two 12 or 14mm nuts(i forgot which) on the master cylinder. one is a lock nut, the other you turn to adjust the pushrod length. there you have it. </TD></TR></TABLE>
awsome. thanks.
awsome. thanks.
Sirex
09-26-2003 07:55 AM
