Tranny Problem
Damn this sucks my car is starting to have sooooooo many problems, trying to get them fixed one at a time.
Now it is my tranny, I got a 1994 Integra GSR. A couple of years ago the clutch went out and i replaced it with a ACT clutch.
I now have a grinding noise that is coming from the tranny ... at least that is what the mechanic said. He said that it is from my "front gears".
I am looking for suggestions ... should I replace the whole tranny with either a ITR tranny or GSR OR should I rebuild that tranny?
Please help I gotta get this done before it totally breaks down on me.
THANKS
Modified by integraGSR213 at 7:45 PM 9/10/2003
THANKS
when is it grinding? if it's at higher RPMs, it's probably the synchros (especially 2-3).....as far as rebuilding the GSR tranny, you're gonna spend about the same amount as buying a used/rebuilt ITR tranny....
i was in the same boat and decided to go with the ITR tranny that i bought from brian (b18c1_powered_si) and it was the best upgrade i did on my car.....love LSD and the closer ratios
i just replaced my tranny. It cost a total of 1500. I had to get a used gsr tranny and a new clutch put in...some other things added also. It was a pain.
change your tranny fluid and see if its sparkly....if it is your tranny is cooked.
If not might be the release bearing as he said (allthough I'm not sure how)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraGSR213 »</TD></TR><TR><TD CLASS="quote">yes it does
... what should I do?</TD></TR></TABLE>
might just be a throwout bearing then....replace that before doing a tranny....might as well do a clutch while your in there.....just my .02
... what should I do?</TD></TR></TABLE>might just be a throwout bearing then....replace that before doing a tranny....might as well do a clutch while your in there.....just my .02
