Problem diagnosis
Old Sep 9, 2003 | 06:44 PM
Jet Black's Avatar
Default Problem diagnosis
I'm pretty sure its the starter, but I wanna double check with you guys.
The problem has been on and off for months, some days I'll go to start the car and I'll just hear click, then I'll try again and it will start. Later on it would turn a bit stop, then just click, I'd try again and it would start.
The other day we ran the stereo a while and the car wouldnt start again...figgured it was a dead batt, so we push started it (started at maybe 5 kph). Drove it for 45 minutes to charge....Tried tp start it again...click...click...nothing....push started it again down a hill...this time it had to get to about 15 kph to start. (I assume this means the battery was lower since it took a higher speed to start the car). So I figgured my alt wasny charging. Just for kciks I cranked it while it was idling to try and spin the starter in case it was on a bad spot. Car started fine after that for about 3 weeks.
Today I went to crank it, spun 2 or 3 times and died....have only been getting click click since. I push started it and tried to crank it at idle to spin the starter again.....but nothing happens...the solenoid doesnt even seem to engage cause I dont hear anything...no grinding...nothing. The ABS light does come on for about 3 seconds when I do that tho.
I checked my voltage on the batt...its at 12.59 V. When the car is at idle with everything off except the daytime running lights, I get 14.49 volts. I put my headlights and highbeams + rear defroster on and at idle I get 13 V. I think this means the alternator is charging probperly. I dont have the equipement to check the power output and dont feel like removing it to check...but I believe this is normal.
So in conclusion...bad starter? Just unsure why it would just completely stop spinning/...BTW I beat on it with a hammer and nothing happened.
Old Sep 9, 2003 | 07:23 PM
Cone's Avatar
Default Re: Problem diagnosis (Jet Black)
sounds like the starter is the culprit. Also, check the connections on the starter. Does Autozone do free testing on starters? Might wanna take it to them.
-Andrew
Old Sep 10, 2003 | 07:14 AM
Jet Black's Avatar
Default Re: Problem diagnosis (Stealth 95 GS-R)
I checked the connections...they are tight.
Alass there is no autozone in canada. I'll replace it and hope.
Does the alternator sound fine?
Old Sep 10, 2003 | 08:04 AM
jimc93si's Avatar
Yep, it's the starter. They short out all the time.
Old Sep 10, 2003 | 08:26 AM
Cone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet Black &raquo;</TD></TR><TR><TD CLASS="quote">I checked the connections...they are tight.
Does the alternator sound fine?</TD></TR></TABLE>
yeah, it sounds like your alternator is fine, I'd say check out the starter...it could be other things, but it's usually the starter...mine is going too...
Old Sep 10, 2003 | 12:37 PM
Jet Black's Avatar
Hehe....I picked one up for 141$ Can
Not to be an ***...but parts are ******* expensive in the states. I was there on vacation and had the same problem....Autoparts extra or something liek taht wanted 280$ us for a rebuilt one
Old Sep 10, 2003 | 04:27 PM
Cone's Avatar
hmmm, Autozone has starters with a lifetime warranty for like $150...
-Andrew
Old Sep 10, 2003 | 05:15 PM
Jet Black's Avatar
*crying*
Where the hell did I go then....the price was ******* rediculous. Auto something.
Dammit....beeing a canadian is tough
Old Sep 10, 2003 | 06:06 PM
jimc93si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet Black &raquo;</TD></TR><TR><TD CLASS="quote">*crying*
Dammit....beeing a canadian is tough</TD></TR></TABLE>
My best friend was Canadian. I felt bad for him every day.
Old Sep 10, 2003 | 07:07 PM
Cone's Avatar
Default Re: Problem diagnosis (jimc93si)
hahaha, maybe it was AutoValue, or Advance Auto or something, I dunno...I don't get out much.
jkalex05
Aug 31, 2009 10:31 PM
everlight44
Feb 7, 2009 11:35 AM
EjSex
Aug 17, 2007 08:20 PM
nighttrain33
10
Feb 25, 2007 08:10 PM
