Header
Old Sep 9, 2003 | 07:46 PM
IntegraBoy04's Avatar
Default Header
I was wondering if a header for a B16 will fit a B18B? My friend has an almost new DC 4-2-1 that he said he will sell me for 120.
Old Sep 9, 2003 | 07:50 PM
ggangtong81's Avatar
Default Re: Header (IntegraBoy04)
yes it will fit. both of them are b series. should fit perfectly.
Old Sep 9, 2003 | 07:57 PM
Default Re: Header (ggangtong81)
So they have the same size collecter? And what all would I have to buy to install it?
Old Sep 9, 2003 | 10:33 PM
xteg95's Avatar
it will bolt right up, the collector size should be the same, but i think the b18b header is slightly longer...
Old Sep 10, 2003 | 06:42 AM
Default Re: Header (xteg01)
So I would have to get some kind of modification? Or will it go right up with my stock cat and Greddy Evo?
Old Sep 10, 2003 | 08:26 AM
neo1z's Avatar
You will need modification. Itll bolt to the head but not right up to the cat.
Old Sep 10, 2003 | 08:27 AM
neo1z's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ggangtong81 &raquo;</TD></TR><TR><TD CLASS="quote">yes it will fit. both of them are b series. should fit perfectly.</TD></TR></TABLE>
Actually - most b-series headers are not interchangable.
Old Sep 10, 2003 | 08:53 AM
RedStarGsr's Avatar
it may not clear the oil pan, only one way to find out... and yes you will need to push back the cat, (chop some exhaust off) b/c the gsr has an extremely short header.
Old Sep 10, 2003 | 11:45 AM
Default Re: (RedStarGsr)
What does the GSR header have to do with anything? this guy has a header for an Si, and i have an LS.
Old Sep 10, 2003 | 12:03 PM
Hites
Guest
Posts: n/a
NOT an exact fit; found that out after i was sent a header for a civic when i ordered one for my teg.
Old Sep 10, 2003 | 08:04 PM
Default Re: Header (Hites)
Did you make it fit? If so, how hard was it?
Old Sep 10, 2003 | 09:23 PM
Cone's Avatar
oil pan could affect it...I forgot if the LS motor is exempt from this or not...so many rules to remember...
Old Sep 11, 2003 | 06:12 AM
Default Re: Header (Stealth 95 GS-R)
What do you mean by that?
Old Sep 11, 2003 | 07:47 AM
Cone's Avatar
the B18 header is taller than the B16 header, I forgot why, oil pan? block? I dunno, do a search and you'll see what I am talking about.
Old Sep 11, 2003 | 09:50 AM
jonsteR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth 95 GS-R &raquo;</TD></TR><TR><TD CLASS="quote">the B18 header is taller than the B16 header, I forgot why, oil pan? block? I dunno, do a search and you'll see what I am talking about.</TD></TR></TABLE>
B16/17 block is shorter than b16b, b18a/b/c, b20 etc.
Old Sep 11, 2003 | 09:57 AM
Cone's Avatar
Default Re: Header (jonsteR)
yeah, what he said ^
Old Sep 11, 2003 | 11:04 AM
Ok, so it will not fit at all, or with some mods?
Old Sep 11, 2003 | 11:52 AM
Cone's Avatar
I'm leaning towards no on this one...
Old Sep 11, 2003 | 02:47 PM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth 95 GS-R &raquo;</TD></TR><TR><TD CLASS="quote">I'm leaning towards no on this one...</TD></TR></TABLE>
big fat obese lardass ******* NO on this one skipper!
Old Sep 11, 2003 | 02:48 PM
Cone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hites &raquo;</TD></TR><TR><TD CLASS="quote">
big fat obese lardass ******* NO on this one skipper!</TD></TR></TABLE>
I guess Hites seals it then. Hmmm, is this a sig worthy quote?
Old Sep 11, 2003 | 02:53 PM
slo2kgsr's Avatar
I have a b16 header on my LS it clears the oil pan but mine has no flanges to bolt to any hangers and i had to have the collector pipe welded in they cut the flange off my stock header and weld it to the b16 header. Note it gets close to the block and sometimes you can hear a metal ringing but not to often
Old Sep 11, 2003 | 02:56 PM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth 95 GS-R &raquo;</TD></TR><TR><TD CLASS="quote">I guess Hites seals it then. Hmmm, is this a sig worthy quote?</TD></TR></TABLE>
your call gilligan!
R.A.T.
Dec 18, 2007 08:24 AM
watsvtecEK
Sep 11, 2005 11:01 PM
BLK98EX
Jul 3, 2004 09:16 PM
93EH6
Apr 12, 2003 07:16 PM
lilcasino
Mar 28, 2003 07:26 AM
