vtec question
Old Jan 28, 2004 | 10:54 PM
inzaneN1's Avatar
From: INZANE FOR PRESIDENT 2008 .., las vegas nv, U.S.of.A
Default vtec question
im having a problem with my vtec. from time to time it doesnt kick in an tops out at about 6,800k and then other times its fine my vtec will kick in fine and redline at 8k anyone know what could be the problem
Old Jan 28, 2004 | 11:01 PM
gsrguy's Avatar
* B A N N E D *
Default Re: vtec question (inzane)
its vtec mon-thurs the rest of the week its a LS
Old Jan 28, 2004 | 11:52 PM
ElectrnBlueGSR's Avatar
check your oil and get your vtec sylinoid cleaned out
Old Jan 29, 2004 | 06:57 AM
631 Teggy's Avatar
Default Re: vtec question (ElectrnBlueGSR)
Oil Pressure...
Old Jan 29, 2004 | 07:01 AM
Yambor's Avatar
Default Re: vtec question (631 Teggy)
check your vtec oil pressure switch..that might be the problem..if you have a haynes manual it tells you how to check it.
Old Jan 29, 2004 | 07:07 AM
MAV3RiCK478's Avatar
change your solenoid filters.
Old Jan 29, 2004 | 08:07 AM
B_CRUZ!'s Avatar
Default Re: vtec question (MAV3RiCK478)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAV3RiCK478 &raquo;</TD></TR><TR><TD CLASS="quote">change your solenoid filters.</TD></TR></TABLE>
you just clean out the screen... .also for vtec to engage you need to be close to WOT and not feathering the gas pedal slowly.
Old Jan 29, 2004 | 09:18 AM
NeoGSR's Avatar
Default Re: vtec question (Honda2nr4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda2nr4life &raquo;</TD></TR><TR><TD CLASS="quote">check your vtec oil pressure switch..that might be the problem..if you have a haynes manual it tells you how to check it.</TD></TR></TABLE>
is it throwing a code? if not, check your oil....
Old Jan 29, 2004 | 11:57 AM
96-EJ6 B18C's Avatar
Default Re: vtec question (NeoGSR)
Are you letting it warm up all the way before you try to cross VTEC?
Old Jan 29, 2004 | 04:45 PM
inzaneN1's Avatar
i let the car warm up , i recently changed oil , i dont have a computer scanner to check if its throwing a code
Old Jan 29, 2004 | 04:48 PM
integraGSR1's Avatar
my car did that not too long ago, all i did was just clean out the VTEC solonoid and hooked it back, it worked fine ever since.
Old Jan 29, 2004 | 07:06 PM
inzaneN1's Avatar
thx fpr replys everyone
Old Jan 31, 2004 | 09:23 AM
Default Re: (inzane)
Do you have a check engine light?
Old Jan 31, 2004 | 11:31 PM
inzaneN1's Avatar
Default Re: (96-EJ6 B18C)
not at moment it turned on once and thats it
Old Jan 31, 2004 | 11:45 PM
TheGSRGuy's Avatar
You need to meet the five parameters to get VTEC to switch cam lobes.
Temperature: The engine must have reached normal operating temperature.
Throttle Position: The throttle must be open far enough to allow for increased airflow in VTEC.
Vehicle Speed: The car must be in motion (wheels spinning).
RPM: Engine must spin to it's target value. The GS-R will send it's "GO" signal for VTEC at 4400 RPM while the Type R sends it's signal at 5700 RPM.
Oil Pressure: The engine must be operating with normal and safe levels of oil pressure determined by the VTEC pressure switch.
(Thanks to SurferX on Team-Integra.net for the information).
If you don't have one of the five things, you won't switch cam lobes and 'VTEC won't activate' as many people put it.
Old Feb 2, 2004 | 09:18 PM
inzaneN1's Avatar
i went to a shop here and they told me my silinoid might be going out
Old Feb 2, 2004 | 09:24 PM
TheGSRGuy's Avatar
VTEC solenoids can go bad. Look on eBay or on a junked car, you can probably get one fairly cheap. If not, try here:
http://acuraautomotiveparts.org
JSpekBB4
Oct 30, 2007 10:23 PM
skylude23
Mar 28, 2007 02:18 PM
Franken Hatch
16
Oct 3, 2006 07:42 PM
LSracing94
Jun 11, 2006 02:33 PM
My Db2 AinT JDM
May 18, 2004 09:24 PM
