ABS question
Old Jan 27, 2004 | 07:30 AM
Solipsist's Avatar
Default ABS question
My system will make a short buzzing sound then stop, then if I on the road fir a while the ABS warning light comes on. I understand from of Acura/Honda owners that this just happens & I've just got to live with it. WRONG. I replaced my roters, pads, & bled the brake fluid out(dot 3). I still can't that warning light to turn off. What gives?
Old Jan 27, 2004 | 08:56 AM
Caffeine Slug's Avatar
Check the fluid in the ABS reservoir, it's probably low. When it gets too low, it does just what you described.
Old Jan 27, 2004 | 09:33 AM
JimBlake's Avatar
Default Re: (Caffeine Slug)
When you bled your brakes, did you also bleed the ABS fluid? It's got it's own bleed valve...
mfrs
Sep 5, 2015 12:32 PM
jonzel
Jul 27, 2005 03:29 PM
khenning
Oct 15, 2004 11:33 AM
Fez
Aug 29, 2002 07:36 AM
