SRR lca problem on DC2 !! Help !!
Old Jan 29, 2004 | 08:01 PM
teg_dc4's Avatar
Default SRR lca problem on DC2 !! Help !!
hey, guys...
I recently installed SRR lca to my 94 teg RS, however, I am having the problem to install the OEM sway bar to my lca. The installer said I should have another bushing installed to lca in order I can put the sway bar on it!! Does anyone know where or how I can solve this problem???
any info will be great!!
THX
Old Mar 23, 2004 | 07:29 PM
dohcroc's Avatar
Default Re: SRR lca problem on DC2 !! Help !! (teg_dc4)
bump i want to know this too
Old Mar 24, 2004 | 07:02 AM
JDMjames's Avatar
I got the SPC LCAs and I had no problems with my sway bar going on.
how is it not going on?
Old Mar 24, 2004 | 09:32 PM
stumpyf4's Avatar
I believe the SRR's don't have a threaded boss like the OEM ones, just a through hole. You probably won't need a bushing since the sway bar end link has one, you need a spacer with a longer nut and bolt. Get some lock washers too. Spacer goes between the end link and the control arms. You could ghetto it and just put a stack of washers instead.
natdor793
Suspension & Brakes
Mar 9, 2015 07:43 AM
KCUF_DB8
Suspension & Brakes
Dec 15, 2009 10:07 PM
anonymus913
Oct 21, 2009 01:15 PM
