idle problem: 2000 integra LS
Old May 19, 2004 | 05:29 AM
bluebomb's Avatar
Default idle problem: 2000 integra LS
hey,
I had some problems with my engine, so we had to do some work on it:
head gasket
intake manifold gasket
now that its all together again, and running (after we found out the fan never worked) the idle is f-d. It goes up and down between 1000 RPM and 1500 RPM. Is it possible for the IEC to be messed up?
Letme know if it might be something else, or what you think!
Thanks
Johan Broersma
Old May 19, 2004 | 09:26 AM
Fuuma0083's Avatar
Default Re: idle problem: 2000 integra LS (bluebomb)
It might be the intake manifold leak.
Spray some starter fluid around the intake manifold and have someone watch to see if the RPM reacts to it.
Old May 19, 2004 | 09:33 AM
greaseball's Avatar
Default Re: idle problem: 2000 integra LS (Fuuma0083)
agreed. spray starter fluid or carb cleaner around your im. your car will stumble if there is a leak.
dcn2tweek
May 15, 2010 05:24 PM
ilu
Apr 19, 2006 03:08 PM
Out of every "game"
Feb 8, 2006 01:12 PM
snowblind7x
Oct 11, 2005 04:10 AM
98itr0448
Jul 10, 2004 03:17 PM
