ABS removal?
Old May 15, 2004 | 01:39 PM
rochnyteg's Avatar
Default ABS removal?
is it ok to take out the abs system, i do not like abs at all. since i do not want it can i take everything out? where would i find the diagram for all the parts involved? save some wt. any help would be great.
Old May 16, 2004 | 05:55 PM
ek9jdm's Avatar
Default Re: ABS removal? (rochnyteg)
just keep it in until you do major mods to your car, its not worth it, you can just unplug the box, but if you wanna remove the whole abs system, you'll need to replace every brake line
Old May 16, 2004 | 06:18 PM
hotintegranights's Avatar
Default Re: ABS removal? (ek9jdm)
y do you want to remove the abs? i hope you know its only about 12lbs
Old May 16, 2004 | 07:44 PM
Danger's Avatar
Default Re: ABS removal? (hotintegranights)
go to the dealer and have them print out a engine bay shot of a integra RS , watever year you have . you will need the parts from that car to take out the abs from your current car .
Old May 17, 2004 | 01:26 PM
rochnyteg's Avatar
Default Re: ABS removal? (JonnyDanger)
Thanks for the info, i just don't like the abs system i like to be in total contol, had a bad experence in my old teg in the snow. i'm planning on getting ss lines soon so, i think ill just change everything out, doing alum fuel lines to ill do that at the same time.
Old May 17, 2004 | 02:13 PM
TeamSTEALTH GSR's Avatar
u'll need integra RS proportion(sp?) valve and the front brake lines.... u can keep your rear brake lines.
Old May 17, 2004 | 03:28 PM
RedGSR's Avatar
If you are planning to sell the ABS sensor, I would like to buy them from you.
Old May 17, 2004 | 04:02 PM
skunked's Avatar
I ditched my ABS out of my GSR. You need to buy a RS proportioning valve and a couple of lines. I bought brake lines from a local auto parts store along with a brake line bending tool and flare tool for the end of the lines and made them myself. The ABS is heavier than I thought. PM me if you need any details.
Mat
Old May 21, 2004 | 08:34 AM
drumking15's Avatar
anyone have pictures of a RS prop valve in an RS...i want to see how the stock lines are set up
Old Jun 25, 2004 | 05:58 PM
Reilly's Avatar
Default Re: ABS removal? (skunked)
PM'd
Old Jul 15, 2004 | 12:49 AM
kaj's Avatar
kaj
Default Re: ABS removal? (Reilly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reilly &raquo;</TD></TR><TR><TD CLASS="quote">PM'd </TD></TR></TABLE>
ditto
IT'S ME DAVID
Sep 10, 2009 08:27 PM
95_red_dc
Oct 17, 2008 11:03 PM
Vcastro
Oct 13, 2006 08:46 AM
AK94GSR
Sep 21, 2004 09:07 PM
