Electrical Problem... Please Help...
Old May 18, 2004 | 07:28 AM
SSBGSR88's Avatar
New User
Default Electrical Problem... Please Help...
I have this weird electrical problem in my car and don't understand what is happening. For some reason my car loses power and it happens at random. The only way to get power back into the car is by wiggling the positive cable on the battery. Sometimes it even occurs when I drive. The power just shuts off and I have to neutral it and pull it to the side of the road, pop the hood and wiggle the positive cable on the battery again. I was wondering if anyone can help me with this annoying problem. Thank You.
Old May 18, 2004 | 07:59 AM
JimBlake's Avatar
Default Re: Electrical Problem... Please Help... (SSBGSR88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBGSR88 &raquo;</TD></TR><TR><TD CLASS="quote">... The only way to get power back into the car is by wiggling the positive cable on the battery...</TD></TR></TABLE>Sounds like you've already figured it out. Maybe you ought to clean & tighten that connection so it doesn't get loose while you drive.
While you're in there, you could also check/clean/tighten the OTHER end of each battery cable, too. Disconnect the negative cable before messing with the positive one.
Old May 18, 2004 | 10:26 AM
PlastikOwl
Guest
Posts: n/a
Default Re: Electrical Problem... Please Help... (JimBlake)
you can buy a battery terminal brush pretty inexpensively. It'll get rid of the corrosion. Also check all of your grounds.
Tallon22
Honda Civic (2001 - 2005)
Jun 22, 2014 11:17 AM
RA122125
Aug 26, 2011 02:15 PM
simonEp3
Jul 14, 2008 04:49 PM
I Like Hondas
21
Sep 29, 2006 02:56 PM
jdmCivic925
Aug 26, 2004 11:58 AM
