HELP ME PLEASEE......!!!!!!
Old May 19, 2004 | 05:45 AM
G-bonic's Avatar
Hijacked
Default HELP ME PLEASEE ENGINE KNOCKING NOISE ......!!!!!!
Last sunday nite i went to moreno valley and all the sudden when i was goin up hill the engine temp guage went up slowly all the to the red line (overheat) and then i heard some knocking noise on my engine. When i open the hood it was smokin a lil so i realize that there was a coolant leak where the timing belt at underneath... and it sounds like a grinder sounds like my pistons and my valves are messed up .. am i rite wat im thinkin about valves and pistons? i can start the car but i dont to, cause i kno its gonna get worse. is ther anyone here ever had experienced this before, if so pls let me kno and some advise... i feel sorry for my teggy man.... and if have to change the pistons can i put civic or teggy type r pistons ??? i got 96 integra LS thats wut im plannin to do and change the valves wit some high performance one.... any1 live in OC can help me fix it im in buena park and i dont have that much budget rite now, is there anyways i can get it fix below 1 gran.. if any gud tuner lived close to me email me at ecko121979@hotmail.com or IM me ..thank you all help will be appreciated...
Modified by Stock_LS at 8:19 AM 5/19/2004
Old May 19, 2004 | 06:16 AM
greaseball's Avatar
Default Re: HELP ME PLEASEE......!!!!!! (Stock_LS)
sounds like you may have blown your head gasket.
Old May 19, 2004 | 06:47 AM
JBBNJ609's Avatar
you should rename your post so more people help you
R6E6I6D's Avatar
Default Re: HELP ME PLEASEE......!!!!!! (greaseball)
I own a second gen 90 integra and believe me i have experienced some timing problems before!!!, but if i were to guess by the sounds of it you blew your water pump which is located right where the coolant is leaking... sorry take the valve cover off and at least check out what is wrong with it before over paying someone.... remove all the plugs and wires( mark each of them off) then take off the valve cover, after this remove the timing cover on the right side of your motor and just look at the water pump, I have seen water pumps that have believe it or not cracked and thrown an impellor and fucked all the timing gears/belts/ followed by the entire rotating assembly.
Once this is all apart just look at it and figure out the problem because id hate to see another proud owner of a teggy getting ripped off on a job that should cost around 350$$ if its just the WP
Old May 19, 2004 | 06:57 AM
IN VTEC's Avatar
Maybe you just thrashed the water pump bearing.
Old May 19, 2004 | 07:26 AM
greaseball's Avatar
Default Re: HELP ME PLEASEE......!!!!!! (R6E6I6D)
forgot about that. i agree, check h20 pump.
Old May 19, 2004 | 07:29 AM
Sack Master's Avatar
Do a compression/leakdown test. The most common thing to happen when severly overheating an engine is for the rings to fry.
Old May 19, 2004 | 09:07 PM
G-bonic's Avatar
Hijacked
Default Re: HELP ME PLEASEE ENGINE KNOCKING NOISE ......!!!!!! (Stock_LS)
Old May 19, 2004 | 09:11 PM
mr.beeks's Avatar
sorry to burst your bubble
but this is major damage
timming belt
seals
waterpump
resurfacing head
checking valves
good luck...
Old May 21, 2004 | 07:20 PM
G-bonic's Avatar
Hijacked
Old May 21, 2004 | 07:25 PM
whiteyGSR's Avatar
hmm i'd agree with beeks. could be a bunch of things.
Old May 30, 2004 | 11:24 AM
G-bonic's Avatar
Hijacked
PROBLEM SOLVED I SPENT $350 GOT MY WATERPUMP CHANGED MY TENSIONARE BEARING, AND MY BELTS... WELL DONE ....GUD JOB TO MY MECHANIC....
jantaasen
Sep 18, 2018 09:03 AM
1A4
Mar 28, 2008 01:18 PM
smokinsi
Jul 25, 2004 05:51 AM
Anubyss
May 3, 2002 09:48 PM
