help check engine light
Old May 18, 2004 | 10:23 AM
paeaknoy's Avatar
Default help check engine light
My car is a 98 GSR with about 58,000 miles on it and is throwing a check engine light the code that popped up is a 45. I looked it up and it says something about the fuel system. The thing is that when I ride in the car sometimes it turns on and sometimes it turns off. My friend says it has something to do with the fuel o2 sensor Im not sure. I have emissions by the end of next month and I was wondering if I can just unplug the battery and take the emissions, can i still pass it?
Old May 18, 2004 | 10:30 AM
SuzukaBlueAP2's Avatar
Default Re: help check engine light (paeaknoy)
Sometimes it turns off? Seems near impossible. OBDII stores the code and keeps the light on until it is cleared from the ECU.
And code 45 is System too rich, or system too lean. If it's too lean, sure, you'll prob. pass emissions, but you're risking the life of your engine. If it's too rich, you prob. won't pass emissions and will get worse than average fuel mileage.
Old May 18, 2004 | 02:09 PM
paeaknoy's Avatar
Default Re: help check engine light (ScreaminTeg)
the thing is how can i fix the check engine light replace my o2 sensor? my gas mileage is worser than before on a full tank i can get about 250 miles until my gas light comes on but my boy that has the same car can get over 350 miles. the check engine light does goes off when i turn the car off and turn it on. in about 5 minutes its off again and i ride for like 20 miles and it pops back on
Old May 20, 2004 | 03:16 PM
paeaknoy's Avatar
anyone?
Old May 20, 2004 | 05:40 PM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes it turns off? Seems near impossible. OBDII stores the code and keeps the light on until it is cleared from the ECU.</TD></TR></TABLE>
actually not impossible. my g/f has a 98 prelude S and it throws the CEL intermittently. it will stay on for a couple of weeks and then turn off for the same amount of time.
Old May 20, 2004 | 05:46 PM
Default Re: help check engine light (svtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svtec &raquo;</TD></TR><TR><TD CLASS="quote">
actually not impossible. my g/f has a 98 prelude S and it throws the CEL intermittently. it will stay on for a couple of weeks and then turn off for the same amount of time.</TD></TR></TABLE>
hmm...never heard of that happening before. Shouldn't it still be stored in the ECU? And I don't know where you are from, but, is there a Prelude S in the states? I thought in 98 there was the base model and the SH, correct?
anyways, that's the first I've heard of the CEL coming on and shutting off in an OBDII car. Learn something new everyday.
Old May 20, 2004 | 05:54 PM
svtec's Avatar
L D E S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">hmm...never heard of that happening before. Shouldn't it still be stored in the ECU? And I don't know where you are from, but, is there a Prelude S in the states? I thought in 98 there was the base model and the SH, correct?
anyways, that's the first I've heard of the CEL coming on and shutting off in an OBDII car. Learn something new everyday.</TD></TR></TABLE>
sorry, i guess i meant base model. for some reason i always thought it was called the S. i guess i learned something new as well. i think the code is stored, but i don't notice any problems. i should prolly take it to the dealership to see what the hell is wrong with it.
Old May 21, 2004 | 04:04 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">OBDII stores the code and keeps the light on until it is cleared from the ECU.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svtec &raquo;</TD></TR><TR><TD CLASS="quote">actually not impossible. my g/f has a 98 prelude S and it throws the CEL intermittently. it will stay on for a couple of weeks and then turn off for the same amount of time.</TD></TR></TABLE>
Depends on what the error is.
Old May 21, 2004 | 09:09 PM
Toddgsr's Avatar
Mine did that and someone told me to always put 93 octane in your car and it fixed the problem.
Old May 21, 2004 | 09:15 PM
Sack Master's Avatar
Default Re: help check engine light (Toddgsr)
Sometimes it will be a cylinder misfire or something like that and it will fix itself and shut the CEL off. I'm NOT speaking from my experiences with OBD-II hondas but OBD-II mustangs .
nsxter
May 12, 2010 04:24 PM
Project99EK
Jan 16, 2004 05:13 AM
