alignment q's
Old May 18, 2004 | 06:21 PM
RallyRedGT-V6's Avatar
Default alignment q's
oK..just lowered the car on h&r sports...took it for an alignment..
they could only set toe-in..
here's my current measurementgs
Front
Camber L: -3.3 R: -2.3
Caster L: -1.6 R: -.7
Toe L: +.01 R:-.01 [from -1.12, and -.26
steer ahead is at .01 from -1.38
rear thrust is .07
will i notice significant wear with that camber? i'll put a kit on this summer, what kit do you reccomend?
basically..what do you think of the numbers
and..what is caster, steer ahead, and thrust angle?
sorry for being dumb
Old May 18, 2004 | 07:53 PM
Xymox007's Avatar
Default Re: alignment q's (96integra)
Try posting here: https://honda-tech.com/zeroforum?id=15
Old May 18, 2004 | 08:33 PM
Sukebei Oni's Avatar
Default Re: alignment q's (Xymox007)
wheres the specs for the rear?
you'll probably have camber wear if you didn't adjust the rear toe.
Old May 18, 2004 | 08:58 PM
ragerized's Avatar
Default Re: alignment q's (Sukebei Oni)
yeah, get that toe neutralized.
camber doesnt wear tires, toe does.
Old May 18, 2004 | 11:05 PM
96dc2's Avatar
Default Re: alignment q's (ragerized)
Yeah, what's the rear toe settings?
Old May 19, 2004 | 03:08 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: alignment q's (96dc2)
I would like to see the thrust angle closer to 0.
Unfortunataly -3.3 on the front left WILL wear those tires, no matter what the toe is. What the hell has that car hit, because that is NOT normal for the camber to be that bad on the front left, especially with just H&R Sport springs. Front right camber looks spot on for those springs.
Old May 19, 2004 | 04:00 AM
m3bluegsr's Avatar
Default Re: alignment q's (PatrickGSR94)
like they said toe is the main cause of tire wear. if your worried about the camber still then get a camber kit and have them 0 it out.
Exia
Suspension & Brakes
Feb 11, 2013 05:00 PM
jdmztrane
Jul 19, 2008 06:20 AM
redDAinteg
Apr 29, 2008 06:30 AM
k-man
Aug 8, 2003 06:41 PM
1.7na
Mar 20, 2003 03:22 PM
