Flywheel
Hey folks,
I just had a custom clutch built and was looking at the various flywheels available on the market right now. I am trying to decide between the Toda, Cusco, JUN, and RPS. If anyone has any of these flywheels and could give me their opinions that would be great.
Thanks
Thanks
What do you mean you had a custom clutch built? I don't follow there...
As for the flywheel, what are you going to be doing with the car? Different weight flywheels and different materials will be more suitable for different conditions.
well i dont know too much about the flywheels u named but i have a act flywheelthe streetlight 7.5 pounds i couldnt tell a bit of difference in driveability,except wheni took it all the way through the rpm range, it pulled alot harderfrom 5 and above and it only cost me about 375$ i believe, i dont member cause i bought a flywheel and a cluthc at the same time.
The engine is going to be pulled this winter, and the entire thing is going to be rebuilt... dartons sleves, cp (.0 to 1 comp. pistons, crower rods, skunk2 stage 2 cams, ferra valves, springs, and retainers. I will also be putting on a love fab = length with a GT30R. Anyway, I had a custom clutch build because it only cost me $400 and it will be able to handle 500+ horsepower, while still being very drivable on the street (full disk, that is still sprung). Well, I don't want to drop my tranny just to replace the clutch, so I figured I would get my performance flywheel as well. I want to stay away from aluminum and go with a chromoly flywheel. As stated I will be going turbo and making a fair about of hp.
Anyway, all plans reveiled does anyone have an experience with the rps flywheel? That is the one I am leaning toward, but am confused about the material it is made of. All it says everywhere I look is "billet" which leads me to think aluminum, but i'm not sure. So, if you have any thoughts or opinions on the flywheels listed above I would appreciate hearing them.
well i dunno about those FW's but i have a Unorthodox Racing 8LB flywheel.. the nice thing about it is the friction material is replacable so i cna hang onto the flywheel for as long as i own a B series. this FW is VERY drivable. daily drive NO problem whatsoever. but i can def feel a differenc ein shifts and hard acceleration
http://unorthodoxracing.com/ultral.html
agent marlon
16
Feb 13, 2003 08:20 AM
