integra
Old Dec 16, 2004 | 08:20 AM
b18c1acura's Avatar
Default integra
My 99 gsr has 87,000 miles and is burning oil. The place that has been
doing service on my car said that it is common for these high reving engines to burn a little oil. My dad said my rings are going bad, and to put new rings on my car would cost a fortune. Who do i believe in this situation? I don't want to put new rings on my car if i don't have to! Does anyone else out there own this car and have this same problem? Any help on this would be great.
Old Dec 16, 2004 | 08:57 AM
nickG's Avatar
Default Re: integra (b18c1acura)
how much?? its pretty common to burn a little oil driving the **** out of your car in vtec all the time..check ur oil and add more when needed. its no big deal if its only a little. but i dont know...im no mechanic
Old Dec 16, 2004 | 10:20 AM
2005 TSX's Avatar
Default b18c1acura
When you check the oil, how much oil are you burning/losing and how often do you have to replace/add oil?
Old Dec 16, 2004 | 11:00 AM
gsr_to_the_MAX's Avatar
Default Re: b18c1acura (2001 Integra GSR)
i have the same prob and so does all my buddies with gizzers. its pretty common for a gsr to burn a lil more oil i guess. i just add more when needed
Old Dec 17, 2004 | 09:42 AM
b18c1acura's Avatar
Default Re: integra (nickgmiller0408)
Ok, since my last oil change which was 260 miles ago my dipstick went from being inline with the second hole to being just a little over the half mark; inbetweeen the two holes. I don't know how many qts. that would amount to be but it sure does seem like alot to me.
Old Dec 17, 2004 | 10:29 AM
WORD's Avatar
Yeah, that's alot. Mine has burned almost no oil (a little below the first line) and I'm changing my oil after this post at about 2700 miles. I rev my gsr above 7 at least once a day, usually on the way to school. Mine's a '95 with 124k though. How do you drive this car...pretty hard? There are other possibilities than just the rings...however they are all equally as expensive. Good luck man.
Old Dec 18, 2004 | 02:21 PM
b18c1acura's Avatar
Default Re: integra (WORD)
What else besides the rings would make my car burn oil?
Old Dec 18, 2004 | 02:23 PM
G-bonic's Avatar
Hijacked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1acura &raquo;</TD></TR><TR><TD CLASS="quote">What else besides the rings would make my car burn oil?</TD></TR></TABLE>
high compression... maybe correct me if im wrong
Old Dec 18, 2004 | 02:31 PM
StatGSR's Avatar
bad valve seals is another. does your car smoke at all? i recently rebuilt my GSR with 137K, and it was smoking all the time and just smelled all the time, thats how i knew something was up. i spent 1500 total on a my rebuild, seems to be running just fine now.
Old Dec 18, 2004 | 03:14 PM
newportx's Avatar
Default Re: integra (StatGSR)
yea i had the same prob jsut kept addin oil to my gsr
Old Dec 18, 2004 | 04:24 PM
WORD's Avatar
Default Re: integra (newportx)
UHH OH! Remember how I changed the oil in that last post. Turns out I too have your "problem". I stated my oil level had hardly gone below the first "hi" line. Well, it was barely on the dipstick at all. So, I figured it out. It's definitely the high-rpms that are doing it (of course ). I was taking it easy on the car only going up to about 5 or 6krpms until I got more into the car. I guess I spoke too soon. I will watch it in the future and continue to add oil (just put Mobil 1 in yesterday...good stuff). I'm not rebuilding anything if I can just add oil for the meantime.
Old Dec 18, 2004 | 04:32 PM
b18c1acura's Avatar
yes, it smokes a little. If it were the valve seals would this mean a lot of money in labor?
Old Dec 19, 2004 | 11:44 PM
WORD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1acura &raquo;</TD></TR><TR><TD CLASS="quote">yes, it smokes a little. If it were the valve seals would this mean a lot of money in labor?</TD></TR></TABLE>
=head rebuild. I just think with less than 90k you shouldn't have to already rebuild the head...then again it depends on how it was driven. "a little". How much? All cars tend to smoke a little when starting up, when cold, etc. What color is the smoke...coming out tailpipe right? (anywhere else would be really bad) That's all important. If you do have to rebuild the head, it would be way more expensive for aftermarket cams, valves, springs, etc....(contact skunk2). However, it might be worth it to do the work now while you have the head exposed. I would seriously have it checked out first before you jump into anything expensive. It's really too hard to diagnos online, but a good estimate would be about 1k to get the work done (and that's for a good deal). Once again good luck, I hope you get this worked out.
fernando.
33
May 1, 2009 09:28 AM
meangreenEG
Jan 13, 2009 04:22 PM
vinhtendo
Jan 11, 2008 08:01 AM
HeDge_BB6
Jan 6, 2008 03:59 AM
oMek
Mar 2, 2004 07:25 PM
