grounding points?
Old Dec 16, 2004 | 07:47 AM
a1320addict's Avatar
Default grounding points?
can someone help me out with the top 3 grounding points in the motor bay? i am installing the apexi super ground....and i can choose three grounds..can someone hook it up? todays my day off...i wanna put this on...its been staring at me in the face for a couple of days
Old Dec 16, 2004 | 08:52 AM
nickG's Avatar
Default Re: grounding points? (yehiknowrite)
theres the regular battery ground( from the ground on the battery) theres one on the valve cover, and one on the tranny. just find the old grounds and run the wires to the same places. but clean the spots so you get good metal/metal contact.
Old Dec 16, 2004 | 05:13 PM
Default Re: grounding points? (nickgmiller0408)
thats it? i thought there was one on the blcok and alternator as well...hmm.
ill let you know how it turns out either way
thanks
Old Dec 16, 2004 | 05:25 PM
fenix77's Avatar
not sure if this will help your situation, but my grounding kit is connected from the negative terminal to 4 spots:
1) valve cover
2) vtec solenoid
3) alternator
4) intake manifold
Old Dec 16, 2004 | 05:26 PM
thaiphob's Avatar
Nikon!!!
if you have a b18c1 gsr motor there is one on the vtec switch too
Old Dec 16, 2004 | 05:27 PM
Default Re: grounding points? (thaiphob)
so guys...i do have a b18c1....in my 01 gsr
i got hte apexi kit...one line to the positive battery terminal...one to the negative
then three left
what do you think would be the best? im thining valve cover...trans and im
Old Dec 16, 2004 | 05:29 PM
thaiphob's Avatar
Nikon!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yehiknowrite &raquo;</TD></TR><TR><TD CLASS="quote">so guys...i do have a b18c1....in my 01 gsr
then three left
what do you think would be the best? im thining valve cover...trans and im</TD></TR></TABLE>
those should be fine
Old Dec 16, 2004 | 07:32 PM
speedymon's Avatar
The Apexi superground kit requires power? Why are you running it to the positive battery terminal?
Old Dec 16, 2004 | 08:24 PM
Default Re: grounding points? (speedymon)
its a voltage regulator as well....it takes the batterys power and evens it out...as well as gorunds
shawn69
Apr 2, 2009 09:00 AM
cash459
29
Apr 14, 2008 10:53 AM
xerox445
11
Mar 2, 2004 06:37 PM
ophdehEEzY
Apr 2, 2003 02:48 PM
