JDM conversion? IL
Old Dec 13, 2004 | 06:37 PM
nsxjr2's Avatar
Default JDM conversion? IL
Where did you guys get your JDM Conversion kit put on at in IL.
Thanks
Old Dec 13, 2004 | 06:39 PM
LSvtec03's Avatar
Default Re: JDM conversion? IL (nsxjr2)
go to any good welder or body shop to have them weld on the radiator support, and diy the rest.
Old Dec 13, 2004 | 06:49 PM
AlxSiR7's Avatar
Default Re: JDM conversion? IL (LSvtec03)
yea man.. the rad support is the only tricky part.. and wiring lights up, if your not good with that. but the fenders and bumper cover just bolt right on
Old Dec 13, 2004 | 11:01 PM
jdm_cars's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxjr2 &raquo;</TD></TR><TR><TD CLASS="quote">Where did you guys get your JDM Conversion kit put on at in IL.
Thanks </TD></TR></TABLE>
most important part.... be sure to get your rad support aligned properly before it is welded on... if not, hehe.. you going be staring at a crooked frontend....lol...
BTW, you also need to cut back the sides of the frame for the rad support to sit properly... I found this out when i was comparing the JDM frame to the USDM frame, jdm is already cut back from the factory for the lights to fit in.
Old Dec 14, 2004 | 03:14 AM
nsxjr2's Avatar
Default Re: JDM conversion? IL (jdm_cars)
Thanks for the help.....
RicharDC4
Nov 25, 2005 10:14 AM
Vtec-IsMyAntiDrug
Sep 28, 2004 05:59 PM
junk yard sol
Feb 17, 2003 03:14 PM
DIRep972
Aug 22, 2001 04:48 PM
