abs
Old Dec 14, 2004 | 01:49 PM
bottlefed2's Avatar
Default abs
i drive a 96 integra ls and the abs has started to act funny its like when you slam on the brakes and its kind jerky on the peddle when you do an abs stop or how it works when slipery and you hit the brakes and the abs applys and unapplys the breaks you get that jerkey feel. well now it has started doing that under normal brakeing coming up to stop lights when im almost stoped it acts like the brakes dont work does any one have any ideas?
Old Dec 14, 2004 | 01:55 PM
3.504's Avatar
Default Re: abs (bottlefed2)
did you change your tire size(smaller wheel diameter will cause early or wrong activation of abs)? is an abs light on in the dash? does the abs light in the dash blink? air gap on the wheel sensor could be out of adjustment (if they're adjustable). take it to anyone with an obd2 scanner (preferably acura).
Old Dec 14, 2004 | 04:57 PM
bottlefed2's Avatar
Default Re: abs (3.504)
it has larger rims but i think the the overall tire size is the same the abs light on the dash comes on sometimes but if i turn the car off and then on after it warms up it goes off it hast blinked
Old Dec 15, 2004 | 03:56 AM
JimBlake's Avatar
Read the ABS error code; instructions in the sticky thread at the top here. Tell us what the error code is so we don't have to guess about it.
Wheel/tire size doesn't matter, as long as all 4 are the same.
puggsley2
Apr 12, 2017 06:33 AM
fastrider213
Jul 26, 2009 02:58 PM
integ3
Dec 5, 2006 10:06 AM
218luder
Jun 29, 2006 07:42 AM
DC5 Type-R
Mar 8, 2002 05:52 PM
