Doing Auto-to-Manual conversion need help !!!
Old Apr 26, 2005 | 11:09 AM
Skank_aSS_Dara's Avatar
Default Doing Auto-to-Manual conversion need help !!!
Im doing a auto-to-manual conversion on a DC chassis, the question is can I use a manual tranny MOUNT in this conversion, or would i have to get a aftermarket mount for this conversion, like the hasport/etc,etc,?!?!?!?
dara
Old Apr 26, 2005 | 01:56 PM
Default Re: Doing Auto-to-Manual conversion need help !!! (Skank_aSS_Dara)
bump?!
Old Apr 26, 2005 | 03:00 PM
sykotic's Avatar
you use the mount for the manual tranny.
Old Apr 26, 2005 | 03:12 PM
Default Re: Doing Auto-to-Manual conversion need help !!! (sykotic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotic &raquo;</TD></TR><TR><TD CLASS="quote">you use the mount for the manual tranny.</TD></TR></TABLE>
so i use the manual tranny "mount" right?
Old Apr 26, 2005 | 04:57 PM
Taristin's Avatar
You need the hasport auto to manual part. Since the mount location is different on the manuals.
Old Apr 27, 2005 | 06:08 PM
ALL IMPORT's Avatar
i just did my 96teg ls auto 2 a 2000 gsr man i got alot of answers but have a few of my oun.
Old Apr 27, 2005 | 06:11 PM
ALL IMPORT's Avatar
Default Re: Doing Auto-to-Manual conversion need help !!! (ALL IMPORT)
yes u have to use hasport mount for the tranny. it has the offset fot your stock mount. the new tranny is smaller. if u need pics of sertain things let me know
Old Apr 27, 2005 | 06:16 PM
virusiidx's Avatar
yeah do not use the manual mount, you need a special 'auto to manual' mount, hasport, jdmshit, and place racing (out of business?) has em.
I had this done over last summer, so I know whats involved.
Here's a good thread about it:
https://honda-tech.com/zerothread?id=273253
Old Apr 27, 2005 | 06:23 PM
ALL IMPORT's Avatar
u might as well buy the other 2 mounts cause thier is a big diff. exp with the back mount , it gets ride of about 90% of motor roll. also the driverside mount will help push the one pully away from the frame about 1/4 inch extra. i have about 1/2 from body. the mount will reduce motor sway to. withouit the mount u will be looking at about 1/4 from frame & it might rub under load. i put stage 3 clutchmasters & lsd in gsr tranny. with just the tranny mount i had alot of play & the shifter i could watch it move 3/4 inch under heavy shifting , did all 3 mounts with hasport & its rock hard nop shift play nothing.
hope the info helps u decide, let me know how it goes & if u get the tach to work i could use the info, lol
GOOD LUCK!!!!!!!!!!!
redrocket
Aug 11, 2010 09:08 AM
DA3
Apr 18, 2008 02:55 PM
unclecaveman
Nov 10, 2006 10:17 AM
eg8ferio
Apr 26, 2006 12:44 PM
RICE POLICE SIP
10
Jan 7, 2003 09:05 AM
