clutch problems?..
Old Apr 26, 2005 | 08:23 PM
Johnytang's Avatar
Default clutch problems?..
i picked up my '97 gsr last year with 162k on it and noticed that the clutch was really tight but i had to raise the pedal fairly high until it reached the point of engagement.. i didnt really know if it was a problem at first because i was fairly new to driving a 5spd.. but now after driving other integras i notice a big difference.. i have to raise the pedal well above the halfway mark before it engages.. i've also haven't been able to chirp from 1st to 2nd gear and have been able to do it on my friend's gsr.. do i need to change the whole clutch? or is it the pressure plate or something?
Old Apr 26, 2005 | 09:54 PM
Johnytang's Avatar
anyone??
Old Apr 26, 2005 | 11:02 PM
Johnytang's Avatar
Default Re:
bump
Old Apr 27, 2005 | 09:25 AM
Johnytang's Avatar
Default Re:
?bump?
Old Apr 27, 2005 | 09:53 AM
Cyphear's Avatar
It sounds like your clutch might not be engaging fully. I would try bleeding the clutch lines. it might just be an aftermarket clutch... (mine engages hirer and its a good clutch, but it definitly chirps the tires).
Sorry i couldn't help anymore.
Old Apr 27, 2005 | 10:34 AM
Johnytang's Avatar
Default Re: (Cyphear)
yea, this is still the original clutch.. the previous owner said he hasnt changed anything at all.. could it be that its just due to be changed? everything else is fine its not loose or anything it just doesn't catch until really high..
Old Apr 27, 2005 | 11:23 AM
wreckedmyteg's Avatar
Default Re: (Johnytang)
With 162k on the clock, your probably due for a new clutch.
Then again, I just replaced the clutch in my GSR with 318k. Only reason it needed to be replaced was it physically self destructed, but there was still some meat left on the linings...
Old Apr 27, 2005 | 06:08 PM
Cyphear's Avatar
My ghetto clutch test is to put it in third, rev to about 5k and drop the clutch. if the car bucks and dies, your clutch is good (gripping), if it winds down then dies its slipping.
Old Apr 27, 2005 | 11:00 PM
Johnytang's Avatar
thanks i'l try it tomorrow
mikeycivic
Jun 4, 2007 05:32 PM
blaster834
12
Feb 22, 2005 09:50 AM
Brett
Nov 15, 2002 01:18 AM
onyx00
Sep 20, 2002 10:06 AM
