Smogged and failed!!! help!!!
Old Apr 27, 2005 | 02:39 PM
bucdenny's Avatar
Default Smogged and failed!!! help!!! B18C1 Hatch
Have b18c1 swap on my civic, went to ref first time, failed because my o2 was in back of the cat, purge valve was missing, timing at 9 degrees, but passed the emissions test by a slight margin. Took it back today, fixed all the problem, but failed the emissions. Tech there ran it three times because they thought it might have been the cat wasn't warm enough. Failed by margins. HC and NOx failed by margins. Have new cat, skunk2 manifold, new spark plugs, dc 4-1 headers, and everything else stock. The other day i put that crappy guarantee to past thinging in my fuel. What can be the problem for high HC and NOx?
Here are the smog check results. First test past! Other 3 test, all different readings failed.
Last weeks first test passes, but visual failed
----------- Co2----O2 ----HC(ppm)----------CO(%)-----------NO(ppm)-----Results
-------------------------MAX---MEAS----MAX---MEAS------MAX----MEAS
15 mph---14.8---.0 ---89------88-------.53----.27---------708-----404 PASS
25 mph---14.8---.0----54------54-------.51----.20---------746-----304 PASS
Todays TEST
test 1
----------- Co2----O2 ----HC(ppm)---------CO(%)-----------NO(ppm)-----Results
15 mph---14.9---.2 ---89------88-------.53----.15---------708-----659 PASS
25 mph---15.1---.0----54------48-------.51----.07---------746-----814 FAIL
test 2
15 mph---15.3---.0 ---89------95-------.53----.18---------708-----672 FAIL
25 mph---15.1---.0----54------54-------.51----.05---------746-----331 PASS
test 3
15 mph---15.1---.2 ---89------180------.53----.44---------708-----946 FAIL
25 mph---15.1---.0----54------54-------.51----.05---------746-----579 PASS
Modified by bucdenny at 3:55 PM 4/27/2005
Old Apr 27, 2005 | 07:53 PM
Rpizzle's Avatar
Default Re: Smogged and failed!!! help!!! B18C1 Hatch (bucdenny)
move to PA
Old Apr 27, 2005 | 08:00 PM
b20turboteg's Avatar
I have a guy who will pass it for 170 hit me up if u need help in socal Email Mrv8killer@yahoo.com
Old Apr 27, 2005 | 08:39 PM
WhiteGSR95's Avatar
causes for high hc and nox r, bad egr valve. something wrong with your secondary ignition system.
_F_Combat_F_
May 1, 2007 02:12 PM
bucdenny
22
Apr 28, 2005 11:11 PM
GSRacer1
Oct 9, 2003 10:40 AM
SimbaDogg
Jul 2, 2003 09:17 AM
Racerage1
Jan 31, 2003 07:33 PM
