Window Problem
Old Apr 28, 2005 | 09:02 AM
r3v da t3g's Avatar
Default Window Problem
I have searched and read alot of threads so my eyes hurt and im giving up. The problem is my car was broken into and they bent the **** out of my rear window. . . i drive a DB8. All the other threads are mainly about DC's so wondering if its the same as the back doors? If anyone knows please help!!!!! Thanks In Advance
Old Apr 28, 2005 | 11:42 AM
s2kdre's Avatar
Default Re: Window Problem (r3v da t3g)
are the slides bent?
Old Apr 28, 2005 | 09:38 PM
r3v da t3g's Avatar
Default Re: Window Problem (jdmhonda)
I have no idea but when its fully rolled up it wont fit snuggled with the weathering to keep water from getting inside. Anyone else?
Old Apr 29, 2005 | 10:43 AM
r3v da t3g's Avatar
*Bump* Can anyone help me?????????? I'm sure someone knows how.
Old Apr 29, 2005 | 12:26 PM
Evanmb44's Avatar
take the door panel off and see if you can get it to slide back into its track. or see what is keeping it from going up right
Old Apr 29, 2005 | 12:35 PM
r3v da t3g's Avatar
Default Re: (Turboaddict)
I took it apart but evertying looked fine but when its fully rolled up it wont fit the weathering so water gets in. I've tried tightening all the bolts but no change.
Old Apr 29, 2005 | 01:18 PM
SuzukaBlueAP2's Avatar
Default Re: (r3v da t3g)
is the weather stripping deteriorating? Maybe that's the problem and not the window.
Old Apr 29, 2005 | 01:41 PM
IVI's Avatar
IVI
Default Re: (ScreaminTeg)
broke into my db8 with the front windows, same thing, window doesnt sit flush with the body unless i roll the window down and then roll it back up then it sits flush.
never took it apart to try and fix it tho.
also if im leaving the car, if i slap the door closed holding the top corner of the window, it shuts flush.
Old Apr 29, 2005 | 04:14 PM
r3v da t3g's Avatar
Default Re: (IVI)
Window is fine just the windows, someone on here must know how to fix it. I opened it up again today and compared front to back and they're diff.
phong3992
20
Mar 4, 2011 01:29 AM
EdWord
15
Dec 10, 2009 09:44 PM
charlee
Sep 6, 2006 07:09 PM
KEVlN
11
Nov 11, 2005 08:36 PM
