5 speed conversion
You will need:
Pedal Assembly
Clutch Master Cylinder
Clutch Slave Cylinder
Clutch Lines
Shift Linkage
Flywheel
Clutch
5-Speed Tranny
Shifter Assembly
The conversion is quite easy to do. All the holes are already marked on the chassis (some may be drilled already and just plugged), the shifter assembly should just about bolt straight up. The peadals will bolt right up and I'm pretty sure that the master cylinder will bolt right up also( holes may need to be drilled, I'm not very sure). I helped a kid do the auto to 5 speed conversion on his 99 Civic and it wasn't as hard as I thought it would be.
Pedal Assembly
Clutch Lines
Shift Linkage
Flywheel
Clutch
5-Speed Tranny
Shifter Assembly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">i did the conversion on my 98 ls and i will never do it again. It was worth it but too much time consuming.</TD></TR></TABLE>
Thats true, i've done my conversion on my 98 GS. Well worth it but i'll never would want to do it again. It'll cost more than you think unless you do it yourself. But the good thing is, you would be able to pick your parts from scratch. BTW try searching also, you'll find tons of threads that could help.
Parts you will need.. (I'm doing one myself right now).
Tranny
Manual ECU
Clutch/Flywheel
Clutch/Slave cynlindar
Shift Linkage
Hydraulic Lines
Clutch Resovir
Manual Pedal Assembly (you can get JUST a clutch pedal, but it will be crowded down there.)
Clutch sensor (the thing in the back of the clutch and the wires that connect, pretty much the thing that tells the car it's okay to start).
Starter
New tranny mount (If you get an OEM Honda manual tranny mount you WILL need to weld it, it WILL NOT directly bolt up. Try placeracing, hasport, jdmshit for auto/manual conversion mounts).
Shifter
Shift ****
Shift boot
Also, someone was saying that you need a new intake manifold. THIS IS NOT TRUE.
Tranny
Manual ECU
Clutch/Flywheel
Shift Linkage
Hydraulic Lines
Clutch Resovir
Starter
Shifter
Shift ****
Shift boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow »</TD></TR><TR><TD CLASS="quote">Well not everyone buys stolen GSR trannys (im joking)</TD></TR></TABLE>
I > you.
I > you.
everyone says they do conversions but ive yet to see someone answer my simple question about the tach issue. no one has said anything about getting axels, also thier will be a hole u will need to cut where the auto shift wire came in at ( if not the shift linkage will hit bfore u can bolt it in) . the hole will be about 2by6 inch so u will need to get a steel plate. i cant remember the exact size but i think its about 11by5 plate. also u need a 3 1/4 hole 1/2 inch from one end and center. for a stock dust boot to work u need to go to the junk yard & cut one out of a crashed car. both can be applyed with stainless self tapping screws & a good sealer is high temp fire caulking from home depot . oh also the mounting holes for your shifter wont work u will need to drill new holes about 1 inch back with new bolts ( nylon nuts are smart to use here)
Modified by ALL IMPORT at 2:12 PM 5/2/2005
LSVTEC408
Northern California (Sales)
Sep 24, 2007 12:11 AM
Tony the Tiger
Jun 25, 2002 08:56 PM
