skipped a tooth?
skipped a tooth?
is there any way to see if my timing belt skipped a tooth? could i put it to tdc and check the marks? or do ihave to use a timing light?
Re: skipped a tooth? (b20integrapower)
Yeah, put the crank at TDC and check if the cams are aligned to TDC as well. You could do it with a timing light, but the first method will be more accurate to eliminate any other variables.
koa
05-24-2018 12:05 AM
wantmorepower
04-16-2003 09:52 PM
