code6 ECT- why?
Old Apr 8, 2006 | 06:00 PM
v-tec maz's Avatar
Default code6 ECT- why?
could you get the code 6 if your have no coolant in the engine?
Old Apr 8, 2006 | 06:57 PM
v-tec maz's Avatar
Default Re: code6 ECT- why? (v-tec maz)
bump
Old Apr 8, 2006 | 09:49 PM
wildoutwhitegsr's Avatar
Need a new coolant temperature sensor near the thermostat
Old Apr 9, 2006 | 07:57 AM
v-tec maz's Avatar
Default Re: (wildoutwhitegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wildoutwhitegsr &raquo;</TD></TR><TR><TD CLASS="quote">Need a new coolant temperature sensor near the thermostat</TD></TR></TABLE>
yea but could not having fluid in there cause that?
Old Apr 9, 2006 | 08:03 AM
loudassVTEC's Avatar
Default Re: (v-tec maz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-tec maz &raquo;</TD></TR><TR><TD CLASS="quote">
yea but could not having fluid in there cause that?</TD></TR></TABLE>
I don't think so. The computer reads the resistance of the sensor, and computes the engine temperature from there. With no coolant in the system, it would read high, but probably not cause a check engine light. If you overheated the engine, the sensor might have been destroyed, but I don't think not having coolant would cause the ECU to throw a code.
Old Apr 9, 2006 | 08:25 AM
v-tec maz's Avatar
Default Re: (loudassVTEC)
i never over heated. would you know the clolor on the wire by any chance?
Old Apr 9, 2006 | 02:34 PM
mine are blue and red, but your's might be different, since mine is Converted to OBD-1, and the CTS wires and plug are obd-0. I also have a DA, so if you have a DC, it might be different
Old Apr 9, 2006 | 04:21 PM
v-tec maz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">mine are blue and red, but your's might be different, since mine is Converted to OBD-1, and the CTS wires and plug are obd-0. I also have a DA, so if you have a DC, it might be different
thank man, this is really pissing me off. because i just wired up my v-tec and code65 now this pops up. damnit. btw i have no radiator fluid in teh car thats why im asking
Old Apr 9, 2006 | 08:24 PM
thank man, this is really pissing me off. because i just wired up my v-tec and code65 now this pops up. damnit. btw i have no radiator fluid in teh car thats why im asking </TD></TR></TABLE>
Just fill it up with some anti-freeze and water 50/50 mix, or buy the premixed stuff, and reset your ECU, and see if it comes back on. If not, test the resistance of the CTS, and see if it is bad or not. Warm the engine up to normal operating temperature, and the resistance should be between 200-400 ohms. If it isn't within tolerance, replace the sensor.
JSPECHB
Nov 14, 2014 09:30 AM
racer_X_123
Sep 13, 2005 03:05 PM
eskimo_usd
11
Sep 9, 2005 07:47 PM
oOJ-GrindOo
11
Dec 16, 2004 09:37 AM
SOFLSOL
Sep 3, 2003 03:59 PM
