Need help with engine shaking..
Old Apr 9, 2006 | 06:27 PM
GsRTegKid's Avatar
Default Need help with engine shaking..
I was on my way to rockfalls raceway and forgot to check the oil so i drove all the way to the track with no oil and when i found out my engine started shaking and sutter and at times it would just shut off..it seems like I'm not gettin enough of something but dont know of what.i am changin the oil and put new sparks in and it stills does the same thing..anything would help me alot!!
Old Apr 9, 2006 | 06:30 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: Need help with engine shaking.. (GsRTegKid)
So you had absolutely no oil in the pan when you checked it?
Old Apr 9, 2006 | 06:46 PM
kpop's Avatar
first of all u can't drive without OIL.
motor mounts could be loose or u have a VACCUM leak.
Old Apr 9, 2006 | 06:51 PM
Default Re: Need help with engine shaking.. (kpop)
The bushings could be worn. Does the motor shutter when your car idles or does it shutter when only pressing the accelerator?
nitrofish420's Avatar
You may have caused some internal damage by running it dry. Is it making any noise?
Old Apr 9, 2006 | 06:57 PM
Default Re: Need help with engine shaking.. (nitrofish420)
Well, if there was no oil as claimed, the motor would have seized. That basically means you either burned off all of the oil or had a massive oil leak. Any any case, the oil light would have come on long before.
Old Apr 9, 2006 | 08:35 PM
loudassVTEC's Avatar
Default Re: Need help with engine shaking.. (Johnny Gasparini)
Oil light is more like an idiot light. By the time it comes on, your motor is pretty much done. Although I've seen Hondas go a long ways with the oil light on, before ruining the engine.
Old Apr 9, 2006 | 10:37 PM
GsRTegKid's Avatar
Sorry let me explainit a lil bit better. I was drivin to a race track but i forgot to check the oil and it was about a 2 and a half hour drive, on the way there i miss shift my gear from 3 to 4 and redline the car really bad. I thought it wasnt any big deal so like 20 mins later when we got there we stopped at a redlight and my engine just started to shutter and it stall on me. when i started it back up my idle wouldnt go up more then 1100 and the car would shake really bad and it would stall again. The only to prevent it from stallin again was to step on the gas and high rev, once i went over 40 on 4th everything was fine. When we changed the oil after gettin back it was really black. we also change the spark plugs, We also found out that Exhaust pro messed with my o2 sensor, so we put that back together but after like 10 mins of drivin the light came back on. The engine stills shutter, My friend thinks the timin is off when i miss shift, everything messed up. I know its gonna cost me alot to bring it in a shop but i rather do it myself. hope this is better, I'm really mad at the moment because its the only car i got to work and places.
Old Apr 9, 2006 | 10:43 PM
Default Re: (GsRTegKid)
Now that you mentioned you miss-shifted, you most likely have bent a few valves... maybe put too much stress on a rod. Basically, you are not going to know definitive unless you disassemble the motor.
Old Apr 10, 2006 | 11:26 AM
GsRTegKid's Avatar
Default Re: (Johnny Gasparini)
Went to a auto shop to get a look at it, he check the ignition wires and the third one wasnt gettin much spark so he said it could be fuel injector or ignition wires is bad or cylinder.
Old Apr 10, 2006 | 11:34 AM
Lan's Avatar
Lan
Compression test
Old Apr 11, 2006 | 12:18 PM
GsRTegKid's Avatar
Okay here is the deal. Found Out I bent My vaules. the shop say it would cost me 1100 to fixed. I would get two new vaules and a new gasket so u think 1100 is over priced or is it just right. If was to do it myself for a guy who never really never fixed his engine would it be that hard?
Old Apr 11, 2006 | 12:20 PM
Lauj87's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsRTegKid &raquo;</TD></TR><TR><TD CLASS="quote">Okay here is the deal. Found Out I bent My vaules. the shop say it would cost me 1100 to fixed. I would get two new vaules and a new gasket so u think 1100 is over priced or is it just right. If was to do it myself for a guy who never really never fixed his engine would it be that hard?</TD></TR></TABLE>
yeah sounds about right including labor.
slow_low_eddie
Aug 20, 2014 07:04 PM
kixcrx
18
Jan 15, 2007 12:00 PM
onceabunny
Aug 7, 2006 11:51 PM
NA JDM GSR
Apr 24, 2006 01:37 PM
allmotorEG-SI
Nov 22, 2003 11:11 AM
