Timing belt tension problems
Old Jul 8, 2006 | 07:07 PM
EG civic's Avatar
Default Timing belt tension problems
Today I was checking my timing belt and when i took off the top timing belt cover and turned on the car, i noticed on the long side between exhaust cam and crank that it vibrated pretty badly, like it was touching on the valve cover. There is maybe an inch of movement on the long side of the belt. Any input would help a lot!
Old Jul 8, 2006 | 07:08 PM
EG civic's Avatar
Default Re: Timing belt tension problems (EG civic)
Is that the correct amount of play? When i first tightened the belt i turned the crank three teeth then tightened the tensioner. Is that the correct tensioning method?
Old Jul 8, 2006 | 07:55 PM
jared99's Avatar
I've always just positioned it properly on the crank and cams, disregarding the play between the crank and exhaust cam, then pushed on the tensioner to tighten the slack between crank and e-cam, then tightened the tensioner. I would think turning the crank and tightening would only tighten up one side depending on which direction you were turning the crank.
Old Jul 8, 2006 | 08:02 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
From what i understand doesnt sound like it, honda's run counter clockwise so you would need minimal play on the cam to crank side and let the tensioner pick up the rest on the other side. To quickly check belt tension to see if its tight, grab it with your fingers and try to twist the belt towards yourself (say your standing on the side or your car). It should only be able to twist towards you, if its more than that you need to tighten up the belt a bit more.
Thats just a quick way to check, it usually works.
wk9k
Mar 13, 2012 05:45 PM
00crv
Honda CR-V & Element
Dec 19, 2011 04:11 PM
revolution920
45
Mar 26, 2011 04:47 PM
daylon1650
Feb 21, 2009 07:22 PM
integra6650
Jan 29, 2003 09:18 AM
