Misfire Problem
Old Jul 9, 2006 | 08:47 AM
csudhoff's Avatar
Default Misfire Problem
I just recently aquired a 99 integra that was put together by a local shop. Nothing out of the ordinary. bone stock 99 Integra LS. Car was a shell and was pieced together. New interior, front bumper, fenders, lights, OBD2 LS Engine. ECU was chipped to remove the key emobilizer for the ingition. here is the problem
ECU keeps throwing Misfire cyl#4. - the shop is pretty much "out of ideas"
here is what has been done in attempt to fix this.
New Plugs
New Wires
New ignitor for distributor, then swapped distributors
Injectors
Any ideas? I am loosing faith in the shop that performed the work. It should be nothing complicated. this is once again a BONE STOCK 99 LS.
ANy help is appriciated
Old Jul 9, 2006 | 09:10 AM
jared99's Avatar
Default Re: Misfire Problem (csudhoff)
Run a compression test. You can rent a tester from Autozone and do it yourself, there's instructions on here if you search. You might have a burned/bent valve. The shop should have already tested for that though...
I hope you didn't have to pay too much for all that other work like new plugs, wires, etc. The proper way to test would just be to swap with another cylinder, that way you can eliminate the problem without spending money on parts you're not sure you need.
Old Jul 9, 2006 | 10:10 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Misfire Problem (jared99)
If the compression test shows that cylinder #4 is lower than the other, you may also want to try adjusting the valves to possible correct the problem. If the valves tappets are too tight, you compression can be lowered.
Old Jul 9, 2006 | 10:48 AM
NKlorichi's Avatar
I have the same problem.i have a 94 integra ls turbo charged and i blew the #4 cylinder.i rebuilt the whole motor and put performance rods/pistons and had the head rebuilt and put together.the motor has good comperession on all 4 cylinders but wont start but it tries.i have changed the followings with another 94 integra ls...ecu,distrubitor,injectors,plugs/wires,checked all the wirings for shortage and checked the timing like 5 times already and firing order,all cylinders have sparks,it tries to start but it wont.
Old Jul 9, 2006 | 11:04 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Misfire Problem (NKlorichi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NKlorichi &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem.i have a 94 integra ls turbo charged and i blew the #4 cylinder.i rebuilt the whole motor and put performance rods/pistons and had the head rebuilt and put together.the motor has good comperession on all 4 cylinders but wont start but it tries.i have changed the followings with another 94 integra ls...ecu,distrubitor,injectors,plugs/wires,checked all the wirings for shortage and checked the timing like 5 times already and firing order,all cylinders have sparks,it tries to start but it wont.</TD></TR></TABLE>
Have you checked the cam timing?
Old Jul 9, 2006 | 10:28 PM
NKlorichi's Avatar
Yes,i did.tdc on #1 with the timing marks on the cams all the way straight up.the compression in all 4 cylinders are the same so that's another indication that the timing is right.
Old Jul 10, 2006 | 01:40 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (NKlorichi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NKlorichi &raquo;</TD></TR><TR><TD CLASS="quote">Yes,i did.tdc on #1 with the timing marks on the cams all the way straight up.the compression in all 4 cylinders are the same so that's another indication that the timing is right.</TD></TR></TABLE>
Did you find TDC with the white timing mark on the crank pully? The red mark is 16 deg. BTDC.
Chris Gonzalez
Feb 17, 2017 02:08 PM
biggjerryc
Nov 13, 2008 09:48 AM
