B17A1
Old Jul 10, 2006 | 12:31 AM
iheartjayDem's Avatar
Default B17A1
can somone help me out with the specs on this motor?
and does anyone have any experiance with it?
thanks alot.
Old Jul 10, 2006 | 06:25 AM
DR Honda97's Avatar
Default Re: B17A1 (iheartjayDem)
what do you need to know?
Old Jul 10, 2006 | 06:56 AM
Wraith_G2IC's Avatar
Default Re: B17A1 (DR Honda97)
Only made in 92-93 in the USDM GS-R
This is straight from G2IC.com http://www.g2ic.com/specs.php
1.7L, DOHC, 4-cyl., 16-valve with Variable Timing & Lift Electronic Control (VTEC) System
HP, SAE net 160hp @ 7600 rpm
Torque 117 lbs-ft (16.2kg-m) @ 7000 rpm
Redline 8000 rpm
Bore & Stroke 3.19 in x 3.20 in (81mm x 81.4mm)
Displacement 102.4 cu in (1678 cc)
Compression Ratio 9.7 : 1
Old Jul 10, 2006 | 09:41 AM
Default Re: B17A1 (Wraith_G2IC)
thanks..that was very helpfull.
quicksilver1689
Aug 24, 2007 02:39 PM
one power
13
Apr 5, 2007 07:38 PM
civic_minded1987
Honda Civic (2001 - 2005)
40
Nov 22, 2006 03:53 PM
IntegDren614
Apr 29, 2003 07:11 PM
vicz
Mar 27, 2003 07:42 PM
