control arm replacement
Old Jul 9, 2006 | 03:53 PM
londonsupra's Avatar
Default control arm replacement
hey i did a search it yelided nothing..
just wondering how to replace the upper control arm and ball joint.
its a 1995 teg
anything special to know?
thanks
Old Jul 9, 2006 | 03:58 PM
mike9571's Avatar
Default Re: control arm replacement (londonsupra)
You should change all the bushings while your at it.
Old Jul 9, 2006 | 08:20 PM
IN VTEC's Avatar
1.) Remove cotter pin
2.) Remove castle nut
3.) Pop ball joint out of knuckle by hitting the knuckle with a hammer
4.) Unbolt UCA from the shock tower
5.) Tap the castle nut to clean the threads
6.) Loosely install the UCA to the shock tower
7.) Jack up the suspension and guide the ball joint into the knuckle
8.) Install castle nut and cotter pin
Buy a new cotter pin from the hardware store. Buy various sizes if you're not sure which one will properly fit.
The strut assy may need to be removed to make things possible or just easier.
Old Jul 9, 2006 | 08:30 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: control arm replacement (IN VTEC)
FYI you can get a tool that is for popping the ball joints for like 6 bucks at any auto parts store, makes things a little easier. But follow the directions above and you'll be good.
Old Jul 10, 2006 | 01:31 AM
thank you for making my life easier!
MalcolmV8
Apr 5, 2011 09:01 AM
arielb1
Oct 31, 2008 12:29 PM
stealth89hatch
Oct 6, 2005 08:21 AM
ProjectCRXtacy
Dec 13, 2004 05:44 PM
BigD+Itsuki
Jun 24, 2002 10:50 AM
