What are the differences between OBD2 ecus?
Old Jul 8, 2006 | 09:22 PM
TurboGS-R's Avatar
Default What are the differences between OBD2 ecus?
I have a 98 Integra GS-R that I have to return to stock for CA reffing. I have an ECU with Hondata and I don't have the original "chip" (stock one). What year Integra GS-R ECUs will work with my car? I think the 00 and 01 GS-R ECUs are OBD2B and are smaller. Will they work for smogging and visual purposes? Or do I need an ECU from a 96-98 Integra? Or will I only be able to use a 98 Integra ECU?
Old Jul 8, 2006 | 11:21 PM
Dartanian's Avatar
Default Re: What are the differences between OBD2 ecus? (TurboGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboGS-R &raquo;</TD></TR><TR><TD CLASS="quote">I have a 98 Integra GS-R that I have to return to stock for CA reffing. I have an ECU with Hondata and I don't have the original "chip" (stock one). What year Integra GS-R ECUs will work with my car? I think the 00 and 01 GS-R ECUs are OBD2B and are smaller. Will they work for smogging and visual purposes? Or do I need an ECU from a 96-98 Integra? Or will I only be able to use a 98 Integra ECU?</TD></TR></TABLE>
You will need any OBD2a P72. That would be any 96-99 GSR ecu.
The OBD2b ecu will not fit into your exisiting harness.
Old Jul 9, 2006 | 02:56 PM
TurboGS-R's Avatar
Default Re: What are the differences between OBD2 ecus? (Sleeper Style)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style &raquo;</TD></TR><TR><TD CLASS="quote">You will need any OBD2a P72. That would be any 96-99 GSR ecu.
The OBD2b ecu will not fit into your exisiting harness.</TD></TR></TABLE>
Thank you. I didn't know that 00 and 01 GS-Rs had different ECUs.
Old Jul 9, 2006 | 06:20 PM
Ls_V_TurboSi's Avatar
They do.. they wont even work even plug into your car and even if they did they have an immoblizer so you it wouldnt start up anyway..
RhdRicheeee
Mar 27, 2009 05:40 PM
ken'd
Jul 8, 2006 05:01 PM
Ewing8712
Jun 30, 2005 12:56 PM
storyteller446
Mar 28, 2004 08:50 PM
