USDM P28 on a JDM B18C with a test pipe, code or no code?
Old Jul 12, 2006 | 10:59 PM
erikiksaz1's Avatar
Default USDM P28 on a JDM B18C with a test pipe, code or no code?
Does the usdm p28 check for the second o2 sensor? I was just wondering if it'd throw a code due to the lack of a second o2 sensor.
Thanks
Old Jul 12, 2006 | 11:29 PM
Dartanian's Avatar
Default Re: USDM P28 on a JDM B18C with a test pipe, code or no code? (erikiksaz1)
Any OBD1 ECU will not check for a secondary O2 sensor because it isn't programmed to do so.
Old Jul 13, 2006 | 07:59 AM
yee SERIOUS's Avatar
obd1 ecu's are not programmed for two o2 sensors. it only searches for the primary (first o2) sensor. so if you put on a test pipe, better run obd1 for no CEL.
Vomit
Nov 20, 2013 08:24 PM
xKAMILxEK
11
Apr 15, 2010 08:52 AM
sickofitall1113
Jun 9, 2005 12:18 PM
Black R
Jul 13, 2004 07:01 PM
D-SPEED
Jan 18, 2002 08:30 AM
