Which would be better?
Old Jul 11, 2006 | 08:38 AM
n3o's Avatar
n3o
Default Which would be better?
I did a bit of searching and looked in the FAQ sticky above and found nothing. I have been trying to find a car to use for a daily and it came down to RSX-S or ITR. I decided an ITR would probably be better since I will be doing a good deal of autox and possibly track days. Finding a clean ITR has been pretty hard so I started thinking are there alot of differences in between an ITR and GSR? I know for one the engine is different. I assume the suspension is also diff, I don't know if the GSR comes with lsd but I believe the ITR does, and I know the ITR has 5 lug. As far as performance wise goes, would I be better off getting an ITR, or a GSR and doing the I/H/E upgrade? And what are the other performance diff's between the 2 cars other then the stuff I listed?
Old Jul 11, 2006 | 09:16 AM
tempname's Avatar
Default Re: Which would be better? (n3o)
I'd say if you can afford it just go with the RSX-S because if you decide to do more extensive mods in the future the k20 is a better platform to start with as it responds very well to simple bolt-ons. Furthermore, the RSX-S will give you a lot less stress because of the factory immobilizer so at the moment it's much less of a high-theft vehicle like the ITR or the GSR.
But if you still want to go with the ITR or the GSR the ITR has a better suspension, freeer flowing exhaust, the ITR has an lsd (GSR does not), more aggressive cams, higher compression pistons, and a microbalanced crankshaft. Also, I believe the chasis of the ITR has extra weld points for added body rigidity (which would be better for autocross)
Hope that helps?
Old Jul 11, 2006 | 09:22 AM
Ls_V_TurboSi's Avatar
Default Re: Which would be better? (tempname)
Gsr isnt comparable to an ITR..
Get the rsx unless you have a garage.
Old Jul 11, 2006 | 09:33 AM
.91DA.'s Avatar
itr and rsx-s close in hp and tq, but i think the lsd is only in itr not t-s tranny but i could be wrong. if you got money get rsx-s n do t-r tranny swap or just get lsd
and gsr cant compare to itr, your right
Old Jul 11, 2006 | 09:41 AM
n3o's Avatar
n3o
Default Re: Which would be better? (Ls_V_TurboSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi &raquo;</TD></TR><TR><TD CLASS="quote">Gsr isnt comparable to an ITR..
Get the rsx unless you have a garage.</TD></TR></TABLE>
Well, Like I said the car is going to be a daily beater. My project car is a '95 TSi AWD being built for auto-x, and to go fast. I want a nice daily with good torque and loads of fun to drive. Either car is going to be exposed to rain/snow since my Talon wont be used in the winter. And don't start with the "OMG ITS A COLLECTORS CAR YOU CAN'T DO THAT!!!!" because what is the point of owning such a car and barely ever using it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tempname &raquo;</TD></TR><TR><TD CLASS="quote"> I'd say if you can afford it just go with the RSX-S because if you decide to do more extensive mods in the future the k20 is a better platform to start with as it responds very well to simple bolt-ons. Furthermore, the RSX-S will give you a lot less stress because of the factory immobilizer so at the moment it's much less of a high-theft vehicle like the ITR or the GSR.
Hope that helps?
I didn't even think about the immobilizer. Also I won't be doing too many mods since the Talon is the money pit, but you have a point on the K20. I just thought the ITR was quicker then the RSX-S out the box and I heard its alot more fun.
Old Jul 11, 2006 | 09:42 AM
n3o's Avatar
n3o
Default Re: (.91DA.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .91DA. &raquo;</TD></TR><TR><TD CLASS="quote">itr and rsx-s close in hp and tq, but i think the lsd is only in itr not t-s tranny but i could be wrong. if you got money get rsx-s n do t-r tranny swap or just get lsd
and gsr cant compare to itr, your right</TD></TR></TABLE>
Why would you swap out a 6spd for a 5spd?!
Old Jul 11, 2006 | 09:44 AM
H23 Power's Avatar
The ITR is only a hair quicker than a RSX-S, but the RSX will be better for daily because of the extra torque. ITR's prices are REDICULOUS. You can get a much newer RSX for less then the price of a ITR. Oh, and you get a moonroof.
Old Jul 11, 2006 | 09:46 AM
tempname's Avatar
Well in Auto-X it would be close between the ITR and the RSX-S since the ITR has the lsd and the RSX-S doesn't have double wishbone suspension setup in the rear. However, the RSX-S has a slightly better power-band than the ITR and makes a considerable amount of more torque (but when it comes down to the ITR and the RSX-S none of them really have significant amounts of torque). Overall, I would choose the RSX-S because it's a lot safer when it comes to theft and if you're building up a high power dsm, you need all the stress relief you can get.
Old Jul 11, 2006 | 09:51 AM
DA is best's Avatar
true true
Old Jul 11, 2006 | 10:09 AM
n3o's Avatar
n3o
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 Power &raquo;</TD></TR><TR><TD CLASS="quote">The ITR is only a hair quicker than a RSX-S, but the RSX will be better for daily because of the extra torque. ITR's prices are REDICULOUS. You can get a much newer RSX for less then the price of a ITR. Oh, and you get a moonroof. </TD></TR></TABLE>
Good point since my friggin dsm doesnt have one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tempname &raquo;</TD></TR><TR><TD CLASS="quote">Well in Auto-X it would be close between the ITR and the RSX-S since the ITR has the lsd and the RSX-S doesn't have double wishbone suspension setup in the rear. However, the RSX-S has a slightly better power-band than the ITR and makes a considerable amount of more torque (but when it comes down to the ITR and the RSX-S none of them really have significant amounts of torque). Overall, I would choose the RSX-S because it's a lot safer when it comes to theft and if you're building up a high power dsm, you need all the stress relief you can get. </TD></TR></TABLE>
LMAO Definately need a stress relief with a dms lol. As for the suspension, I thought it was double wishbone all around?!?!
Old Jul 11, 2006 | 10:20 AM
scB20teg's Avatar
Any of those cars can be built up pretty easy. You could find a cheap GSR to build up and it would be faster than the stock ITR or stock RSX for less money. The B18c1/5 is a great platform to work with and the K20 is pretty solid with basic bolt ons, cams, and tuning. It just depends on what you want.
Old Jul 11, 2006 | 10:25 AM
n3o's Avatar
n3o
Default Re: Which would be better? (scB20teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scB20teg &raquo;</TD></TR><TR><TD CLASS="quote">Any of those cars can be built up pretty easy. You could find a cheap GSR to build up and it would be faster than the stock ITR or stock RSX for less money. The B18c1/5 is a great platform to work with and the K20 is pretty solid with basic bolt ons, cams, and tuning. It just depends on what you want.</TD></TR></TABLE>
The whole point of these cars is to spend the least amount of money on mods for a decently quick, good handling daily. I am pouring so much money into the talon that I can't afford to mod another car.
Old Jul 11, 2006 | 10:29 AM
I wasnt saying get the rsx unless you have a garage becuase its a collectors car. The car is on the top of every jackers hit list. I would just get the rsx.. Everywhere you go you'll have to worry about the R getting jacked
Old Jul 11, 2006 | 10:33 AM
n3o's Avatar
n3o
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi &raquo;</TD></TR><TR><TD CLASS="quote">I wasnt saying get the rsx unless you have a garage becuase its a collectors car. The car is on the top of every jackers hit list. I would just get the rsx.. Everywhere you go you'll have to worry about the R getting jacked </TD></TR></TABLE>
mm Good point. Even though I highly doubt it would get stolen in my neighborhood (600k+), It only takes people minutes to steal a car, and I do visit hartford and some other ghetto *** towns quite often....
em1_niokka
May 18, 2012 06:33 AM
ck123
Sep 5, 2006 08:20 PM
yoda888
Apr 28, 2004 06:19 PM
evergruven
Jan 21, 2002 03:53 PM
Todd00
59
Jun 22, 2001 11:14 AM
