Overheating
Old Jul 13, 2006 | 11:14 AM
aeon's Avatar
Default Overheating
Well, I just did a motor swap so I can take my car to the ref. Everything went ok, but yesterday I was driving for about 20 minutes and smelled coolant. Looked at my gauge and the needle was pointing past the H (hot). I pull over and pop the hood. The coolant was boiling in my over fill bottle and leaking out of it. I Forgot the night before when I was letting all of the air bubbles out to tighten the top back on. So I wait til my bro comes and I fill up the radiator with water just enough so i can get home. 10 minutes into the drive home, the needle starts going up. so i turn on the heater full blast and the needle goes back down to normal.
today i put some more coolant in and let the car idle for about 10 minutes while having the radiator cap off so the air bubble would come out. I leave for about 1 minute come back and coolant is shoot up out of the radiator. i look at my gauge again and it's at it's normal temp.
sooo.. what do you guys think is the matter? i'm going to change out my thermostat tonight and see what happens. could it also be the water pump?
Old Jul 13, 2006 | 12:37 PM
huepowered's Avatar
Default Re: Overheating (aeon)
same **** happened to me... check your radiator cap.. make sure its in one piece.. if not just replace it.. only like 10 bucks or so
Old Jul 13, 2006 | 02:33 PM
aeon's Avatar
i'll look into that.
Old Jul 13, 2006 | 02:37 PM
BrooX's Avatar
When's the last time you had a T-Stat replacement?
Old Jul 13, 2006 | 06:35 PM
aeon's Avatar
Default Re: Overheating (BrooX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrooX &raquo;</TD></TR><TR><TD CLASS="quote">When's the last time you had a T-Stat replacement? </TD></TR></TABLE>
well i haven't changed it since i got the car. sooo i've put about 30,000 miles on it and it now has about 113,000 miles on it.
Old Jul 13, 2006 | 09:30 PM
lsvtek's Avatar
Default Re: Overheating (huepowered)
head gasket maybe? is there white smoke coming out of your exhaust? if not mayb you have a crack on your radiator cap
Dm914
Jul 21, 2017 07:40 AM
davidbuccaneer
10
Nov 23, 2015 12:40 AM
RG400SmartTowel
Aug 11, 2009 12:34 AM
Mario.
Mar 5, 2005 06:30 PM
yuhdunknow2g
Dec 7, 2004 09:34 PM
