axles need help quick please
Old Jul 10, 2006 | 09:44 PM
95_red_dc's Avatar
Default axles need help quick please
i am trying to replace my drivers side axle that is for a 94 teg and i can not disconnect it from the half shaft, I have tryed useing a flat head and prying on it and also a pry bar any suggestions would help to thanks.
Old Jul 10, 2006 | 10:31 PM
95_red_dc's Avatar
Default Re: axles need help quick please (ls_swaped_crx)
bump
Old Jul 10, 2006 | 11:00 PM
RHDintegXsi's Avatar
try a big effin hammer..works for me
Old Jul 10, 2006 | 11:43 PM
Ls_V_TurboSi's Avatar
Default Re: axles need help quick please (SINFULintegXsi)
I agree.. Just tap it with a hammmer and it will break free
Old Jul 11, 2006 | 12:09 AM
qfast817's Avatar
Default Re: axles need help quick please (Ls_V_TurboSi)
or take the fork off the strut and tap it in between the axle and halfshaft
Old Jul 11, 2006 | 03:31 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: axles need help quick please (qfast817)
Do you have enough room to get the proper amount of leverage from a prybar? If you keep working the prybar or flathead and also have a friend tug on it (it doesn't matter if you break it some more, you're replacing it anyway right?), it will eventually come off. It's too easy to give up.
I've probably changed both sides for my car eleventybillion times since I have the junk *** remans that I get for free. My car is so low the height geometry is all fucked up and causing stress on my axles. Oh well, you gotta pay to play and ride low.
Old Jul 11, 2006 | 07:38 AM
HONDA RR's Avatar
Use a hammer and tap it and it should work.
grg9988
Mar 7, 2008 04:11 PM
eguser
Feb 10, 2007 01:14 PM
CivicK20
Dec 23, 2006 12:25 PM
95_red_dc
Jul 12, 2006 02:56 PM
lonefuzzy79
Jul 10, 2002 08:31 PM
