LS/VTEC HEADER QUESTION
Old Jul 11, 2006 | 09:10 PM
youre_scum's Avatar
Default LS/VTEC HEADER QUESTION
Will I still be able use my existing 4-1 header on my B18B after I swap heads?
Old Jul 11, 2006 | 09:12 PM
Backk InTheDA's Avatar
I hate everything
Default Re: LS/VTEC HEADER QUESTION (youre_scum)
Yeah, a B series is a B series.
Will work just fine.
Old Jul 11, 2006 | 09:14 PM
DC2 Mang's Avatar
Default Re: LS/VTEC HEADER QUESTION (Backk InTheDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Backk InTheDA &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, a B series is a B series.
Will work just fine.</TD></TR></TABLE>
the only b-series header that may have clearances issues on a b18 motor is the b16 header because of the shorter deck heighth
Old Jul 11, 2006 | 09:15 PM
youre_scum's Avatar
Will any other model b series headers fit my engine? Type R? GSR? CTR? .....And still match up to my catalyic?
Old Jul 11, 2006 | 09:25 PM
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youre_scum &raquo;</TD></TR><TR><TD CLASS="quote">Will any other model b series headers fit my engine? Type R? GSR? CTR? .....And still match up to my catalyic?</TD></TR></TABLE>
Like previously stated, w/ the civic type r, it runs a b16, so there may be clearence issues, but all these engines are b series, so they will bolt to you head just fine, just w/ the b16, it may have some clearence issues.
Old Jul 12, 2006 | 07:10 AM
H23 Power's Avatar
some of the headers you listed are different lengths, so you may need to compensate with a different cat or b-pipe.
Old Jul 12, 2006 | 10:16 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: LS/VTEC HEADER QUESTION (DC2 Mang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">
the only b-series header that may have clearances issues on a b18 motor is the b16 header because of the shorter deck heighth</TD></TR></TABLE>
a b16 header is ideal for the lsvtec. because of the fact it's shorter.....if you use a b18b or a GSR it will be looong...
Old Jul 12, 2006 | 10:18 AM
DC2 Mang's Avatar
Like previously stated, w/ the civic type r, it runs a b16, so there may be clearence issues, but all these engines are b series, so they will bolt to you head just fine, just w/ the b16, it may have some clearence issues.</TD></TR></TABLE>
the CTR header will fit because it has the same deck heighth as the b18c blocks
as for the GSR header, you will have to run a longer at to fit it on
ITR, CTR, LS spec headers will fit your car with no problems, but you may need a larger collector on the cat if you get a header with a 2.5 inch collector on it
Old Jul 12, 2006 | 09:27 PM
R3DL1NETHIZ23's Avatar
b series is b series
AllMotaEF9
Nov 5, 2007 11:01 AM
mkinpwrat12g's
Jul 13, 2005 07:16 PM
Contender25
Jun 12, 2005 11:31 PM
SMSP
31
May 9, 2005 05:56 PM
ALLMOTA92EG
Mar 1, 2005 02:25 PM
