side molding
Old Jul 13, 2006 | 04:29 PM
GreddyTegra's Avatar
Default side molding
how much for it to be shaved off?
thanks
Old Jul 13, 2006 | 04:31 PM
Dforce's Avatar
That's what she said!
Default Re: side molding (GreddyTegra)
ask your local paint shop.
Old Jul 13, 2006 | 04:34 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: side molding (Dforce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dforce &raquo;</TD></TR><TR><TD CLASS="quote">ask your local paint shop.</TD></TR></TABLE>
its more than you might think, because to be properly done the holes need to be welded shut, and they will then need to paint both doors, as well as the rear quarter panels. $700-1000 i would guess
Old Jul 13, 2006 | 04:36 PM
Default Re: side molding (BOLO-FTW.)
wowzers
thanks for the fast replys
ps
would alot of bondo work be involved
Old Jul 13, 2006 | 04:40 PM
Guess whos bizzack
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreddyTegra &raquo;</TD></TR><TR><TD CLASS="quote">wowzers
would alot of bondo work be involved</TD></TR></TABLE>
not if it's done the proper way, which is to weld small metal patches in place to cover the holes.
Old Jul 13, 2006 | 04:51 PM
Dforce's Avatar
^^^^yup
Old Jul 13, 2006 | 04:55 PM
Dogginator's Avatar
Daisy... Daisy...
It is not worth it unless you plan to paint the car anyway.
Old Jul 13, 2006 | 05:23 PM
Backk InTheDA's Avatar
I hate everything
Default Re: side molding (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">It is not worth it unless you plan to paint the car anyway.</TD></TR></TABLE>
Exactly
Old Jul 13, 2006 | 06:57 PM
kynetik's Avatar
http://www.team-integra.net/fo...eDESC
http://www.team-integra.net/fo...68167
I like the 2nd method better, but the guy on the 1st method did a great job of rattle canning it afterwards. IMO JB weld should be good enough to do the trick. Metal epoxy is pretty tough to break thru unless you're doing it extremely forcefully.
Old Jul 13, 2006 | 08:38 PM
Default Re: (kynetik)
Thank you man
ill hopefully try it this weekend
Old Jul 13, 2006 | 08:44 PM
DC5StylZ's Avatar
Default Re: (GreddyTegra)
dude dont that guy had all the right equipment and knew what he was doin im telling u its not worth the trouble leave ur molding or get it done ull thank me
Old Jul 13, 2006 | 08:56 PM
singhtyper's Avatar
Default Re: (hondacuraLs)
Look man I jus got my sides and other stuff RESHAVED b/c the guy that did it the first time used bondo and that **** craked and broke off. IF you live near Northern VA.. I can hook u up with my painter... he is the ****... the welded every hole.. and fix some other issues with my car all for $600.. Now it all depends on your paint.. my car is primered so it really didnt matter.. but he really doesnt charge alot for paint work... does awesome job tho.. he is the one that did my bros JDM front on his R.. and is currently doin s15 fronts on Nissans and painting them all..jus weigh out your options. But It looks so much better
Old Jul 13, 2006 | 09:16 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (singhtyper)
Sheet metal behind the hole, mig welded, then bondo to smooth it.
Old Jul 13, 2006 | 09:23 PM
GranadaTeg's Avatar
Old Jul 13, 2006 | 10:24 PM
aaronISthrowed's Avatar
Default Re: side molding (Slo Cord)
I would try but i know i would end up ******* something up.
Old Jul 13, 2006 | 10:37 PM
jdm_bones's Avatar
Default Re: side molding (aaronISthrowed)
Honda sheet metal tends bend and burn holes really easy, I'd save some money and take it to a pro...my .02 cents
WangstaCivic
Paint and Body
26
Apr 30, 2008 09:08 AM
invisible
Dec 18, 2006 08:15 AM
EJ2_B16
13
Jan 17, 2006 02:59 AM
nekoabandoned
Nov 25, 2005 03:41 PM
Atlas
Aug 9, 2004 08:35 PM
