VSS problem??
Old Jul 13, 2006 | 02:02 PM
latindc2's Avatar
Default VSS problem??
Sup guys i was gettin a CEL for VSS so i went to the dealership and got the sensor, now my speed meter needles works, but wierd everytime i get to 7krpms the speedmeter goes crazy, it jump all the way to 140mph! what could be???? TIA
Old Jul 13, 2006 | 05:26 PM
Backk InTheDA's Avatar
I hate everything
Default Re: VSS problem?? (latindc2)
It sounds like its just not installed correctly. I believe you can clean the sensor w/ brake fluid cleaner.
Old Jul 13, 2006 | 08:44 PM
blackeg's Avatar
Default Re: VSS problem?? (Backk InTheDA)
its not the sensor is the connecton in the plug. clean out the wire harness side of the vss plug.
i had probs like that. turns out i had to take a new plug, cut it off. depin and fully clean each of the 3 pins. then i put it back into the plug and soldered the whole thing into my current engine harness. works flawlessly now
dohc_profile
Mar 3, 2009 05:42 AM
NOman0608
May 26, 2007 05:19 PM
d!zZy
Nov 22, 2005 09:49 PM
gaydm.accord
Dec 18, 2003 10:33 AM
