Door Lock
Old Jul 11, 2006 | 01:09 AM
97RSTEG's Avatar
Default Door Lock
Hey Guys I have 97 RS with a door lock problem. The driver side door lock tends to stick and I can’t seem figure out why. The car had power locks installed with the alarm and i figured it was the actuator but today I disengaged it and the door still won’t lock even with the key from the outside. My question is does anyone know what the problem might be or if not, how hard is the door lock to swap?
Old Jul 11, 2006 | 07:25 AM
toffytof's Avatar
i had a similar problem with my passenger side door lock. i just took off the door panel and sprayed wd-40 on the rod and connectors to the lock. it's definitely worth a shot since you are unlikely to make it any worse.
Old Jul 11, 2006 | 07:26 AM
Tizight's Avatar
It happens to mine all the time. I think it is how the alaram was put in because it looks fine when I just use the pager.
Old Jul 11, 2006 | 08:01 AM
stoffius's Avatar
I had the same problem before and after installing actuators. I used and prefer graphite lubricant. Works like a charm.
Old Jul 11, 2006 | 08:05 AM
SuperHonDad's Avatar
Default Re: (stoffius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stoffius &raquo;</TD></TR><TR><TD CLASS="quote"> I used and prefer graphite lubricant. Works like a charm.</TD></TR></TABLE>
The graphite is better because wd40 is a water based lube, still works though. Easy fix same thing happened to my Crx.
Red-Rag-B18
Acura TSX
Apr 30, 2013 09:12 AM
2003CivicLx
Sep 18, 2008 05:14 PM
crx98
Jul 22, 2008 05:44 PM
soon2bdropped
Jan 10, 2008 07:28 PM
Smith Wise
12
Aug 17, 2003 12:03 PM
