tachmeter
Old Jul 10, 2006 | 07:28 PM
ls weez's Avatar
Default tachmeter
doea anyone know how i can get the shift light rpm activated switch on a tachmeter to operate the vtec solenoid ?
Old Jul 10, 2006 | 07:30 PM
GSR Vixen's Avatar
Default Re: tachmeter (ls weez)
This is just a guess......but Ebay sells that kinda stuff
Old Jul 10, 2006 | 08:00 PM
Ls_V_TurboSi's Avatar
Default Re: tachmeter (GSR Vixen)
you have to get a tach that has shift light then set the light to turn on when vtec kicks in.. Why do you want to shif when vtec kicks in?
Old Jul 11, 2006 | 07:51 PM
ls weez's Avatar
Default Re: tachmeter (Ls_V_TurboSi)
no i want the shift light ta activate the vtec so when the shift light comes on the vtec kicks in
Old Jul 11, 2006 | 07:55 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
wow. this forum gets worse with age.
Old Jul 11, 2006 | 08:19 PM
Hybrid 350GT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls weez &raquo;</TD></TR><TR><TD CLASS="quote">no i want the shift light ta activate the vtec so when the shift light comes on the vtec kicks in </TD></TR></TABLE>
A light is not going to make V-tec "kick in". It doesn't work that way.....
V-tec engagement is set by the factory in the ECU. Getting a new ECU, (ie. mugen) or V-tec controller (ie V-AFC) is the only way to adjust when it engages. Odly enough a Shift Light can be programed to turn on at a set RPM that you designate. So I would just set your light to the RPM in which V-tec gets engauged. Like say 5,600 - 5,800 or so. This number will fluxuate if you have a non stock ECU, V-tec Contoller, etc.
Old Jul 11, 2006 | 08:34 PM
jared99's Avatar
This only works if you have solar powered vtec.
crooked muffler
29
Oct 17, 2018 04:54 PM
jdmwannabe3
25
Apr 14, 2006 08:57 PM
ham
Jul 8, 2004 05:58 AM
93slmdcvcsi
12
Nov 3, 2003 07:26 AM
4dohs4mohoes
Sep 28, 2002 06:30 PM
