control panel problem! HELP
Old Dec 5, 2006 | 01:34 PM
blakacintegra's Avatar
Default control panel problem! HELP
where the buttons to change vents from floor to dash to defrostor etc. the buttons work and light up but it does not want to listen to me, the air just keeps coming out a little bit from all of them whats my problem? and when the car warms up the heat will work for about 10 seconds and then get cooler whats my problem there?
Old Dec 5, 2006 | 05:51 PM
JasonST's Avatar
Default Re: control panel problem! HELP (blakacintegra)
Theres a mechanical slider that channels the heat or air to a certain vent when u push the button for which vents u want to use, it could be stuck, but also a little bit of air will always come out the vents just cause that's what happens when ur moving a bit of air will always blow out the vents. Also, if ur heat's not working, check to make sure the heater fan is working, behind the dash board, I think there might be a fuse for it u could try checking. also check and make sure u got plenty of coolant.
Old Dec 6, 2006 | 06:55 AM
ill check the slider your talking about but its def not working bc nothing comes out of the defroster and nothing changes at all when i press button to button..where is the slider located tho? and someone told me to check the blower motor is that different from the heater fan?
Turbo O
May 21, 2012 08:21 AM
fog raw
Nov 4, 2011 05:36 AM
itr1448
Feb 18, 2010 09:31 PM
NDNV
Feb 20, 2009 05:11 AM
CereaLand
Jun 16, 2003 07:45 PM
