Tranny?
Old Dec 3, 2006 | 03:38 PM
IgnitionZ05's Avatar
Default Tranny?
Heres some pics where the leak is coming from.
Just Behind this, is where the leak is
What could be the problem??
Old Dec 3, 2006 | 03:41 PM
lVlemphizStylez's Avatar
Default Re: Tranny? (IgnitionZ05)
can you get a better picture dude i have trouble making out what im looking at..Were talking about a leak behind the slave cylinder between the tranny and the slave?
Old Dec 3, 2006 | 03:43 PM
PrinceAli132's Avatar
Default Re: Tranny? (lVlemphizStylez)
I think its leaking behind the slave cylinder.
Are those two bolts where you see fluid on the bottom/back of that rubber boot in the last pic?
Ali
Old Dec 3, 2006 | 03:44 PM
stumpyf4's Avatar
Looks like the slave cylinder is leaking. If it is indeed leaking the fluid in the clutch master should be low.
Old Dec 3, 2006 | 03:45 PM
Default Re: Tranny? (PrinceAli132)
yes those two bolts is where i see some leakage going on only on the far left bolt. SOrry for the bad quality pictures my camera sucks...btw is this a major problem how much would it cost me???
Old Dec 3, 2006 | 03:57 PM
Its a fairly easy fix, you could probably get a used one on here or a junkyard. For a new one, check http://www.barancoacuraparts.com
Like stumpyf4 mentioned check to see of your clutch master cylinder is low on fluid. Also, did you experiance any problems with your clutch pedal not coming back up.
Ali
young geezer
Mar 23, 2010 08:23 AM
TigerLy
Dec 24, 2008 01:04 PM
IgnitionZ05
Dec 4, 2006 06:52 PM
ApolloSpeed
Feb 12, 2006 12:51 PM
deviant1
Feb 28, 2002 03:03 PM
